Home » Archived » M2M (model-to-model transformation) » ATL transformation
ATL transformation [message #77744] Thu, 27 March 2008 12:50
Originally posted by: yassin.chkouri.imag.fr
I am making a transormation from model to model and generated code from
the latter model.
I put this code . the generation is OK but i have the error message in the
console.
Thank's for your help.
// create an xml resource factory
Resource.Factory factory = new Ecore2XMLResourceFactoryImpl();
Resource poResource = factory.createResource(timedFileURI);
// add the model in the xml resource file
poResource.getContents().add(bipModel);
// and save it
poResource.save(null);
BipTransformation bip2source = new
BipTransformation(bipResources.getBipHome()) ;
bip2source.runBipUntimedTransformation(timedFileURI,
untimedFileURI) ;
bip2source.runBip2SrcTransformation(untimedFileURI) ;
SEVERE: Resource
'/resource/cruise_data/bip/cruise_data_cruise_sys_i_Instance .model' does
not exist.
org.eclipse.core.internal.resources.ResourceException: Resource
not exist.
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:310)
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:193)
org.eclipse.core.internal.resources.Resource.setDerived(Reso urce.java:1478)
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:145)
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:61)
ujf.verimag.bip.transformation.BipTransformation.runBipUntim edTransformation(BipTransformation.java:304)
ujf.verimag.bip.aadl2bip.generation.CreateBipComponent.saveA ndCompleteGeneration(CreateBipComponent.java:364)
ujf.verimag.bip.aadl2bip.generation.AadlBipGeneration.doAaxl Action(AadlBipGeneration.java:61)
edu.cmu.sei.osate.ui.actions.AbstractAaxlAction.processAaxlA ction(AbstractAaxlAction.java:527)
edu.cmu.sei.osate.ui.actions.AbstractAaxlAction.actionBody(A bstractAaxlAction.java:209)
edu.cmu.sei.osate.ui.actions.AaxlReadOnlyActionAsJob$ActionA sJob.runInWorkspace(AaxlReadOnlyActionAsJob.java:137)
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
Previous Topic:[ATL] Does ATL work with Eclipse 3.4 and heavyweight extensions of UML2
Next Topic:[ATL]UML 2 BPEL transformation
Current Time: Sun Nov 23 13:35:49 EST 2025
Powered by FUDForum. Page generated in 0.03447 seconds
