Home » Modeling » GMF (Graphical Modeling Framework) » Relaxed dependency on GDI+ ?
Relaxed dependency on GDI+ ? [message #77720] Tue, 14 November 2006 21:13 Go to next message
My diagram had dependency on GDI+ when I used GMF 1.0 build back in
Sept. The problem was that the nodes did not paint in main canvas.
I did not change my code but noticed it worked with recent GMF 1.0.1
build without GDI+. Just want to double check, did GMF diagram runtime
make some changes to handle non GDI+ case so that node still paint?
Thanks.
Li
Re: Relaxed dependency on GDI+ ? [message #77859 is a reply to message #77720] Wed, 15 November 2006 09:41 Go to previous message
As of version 1.0.1, GMF detects whether your system supports advanced
graphics capabilities (eg GDI+ on Windows and Cairo on Linux machines).
If it is not supported on your platform, advanced graphics is turned
off within GMF.
More details can be found at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=154982
David
Li Ding wrote:
> Thanks.
> Li
Previous Topic:Setting a property that should not change afterwards
Next Topic:regarding GMF Commands
Current Time: Wed Nov 05 05:36:03 EST 2025
Powered by FUDForum. Page generated in 0.03175 seconds
