Home » Language IDEs » ServerTools (WTP) » ClassCastException trying to create EJB Project
ClassCastException trying to create EJB Project [message #77704] Sun, 27 February 2005 09:29 Go to next message
Did a clean install of Eclipse M5 and WTP M3. Trying to create a new EJB
Project gives me following stack trace. This stack trace occurs when you
choose 2.0 as the specification version but not when you choose 2.1.
Also after the stack trace has occured whenever i try to type something
to the name field of the ejb project wizard my characters are doubled
(eg. "TestProject" becomes TTeessttPPrroojjeecctt").
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:355)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
org.eclipse.wst.common.frameworks.ui.WTPWizard.performFinish (WTPWizard.java:90)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:670)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:342)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1009)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2728)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2427)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:173)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:100 3)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:557)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:507)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:421)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Caused by: java.lang.ClassCastException
org.eclipse.wst.common.frameworks.operations.WTPOperationDat aModel.getIntProperty(WTPOperationDataModel.java:487)
org.eclipse.jst.j2ee.application.operations.J2EEModuleCreati onOperation.setVersion(J2EEModuleCreationOperation.java:144)
org.eclipse.jst.j2ee.application.operations.J2EEModuleCreati onOperation.createProject(J2EEModuleCreationOperation.java:9 6)
org.eclipse.jst.j2ee.application.operations.J2EEModuleCreati onOperation.execute(J2EEModuleCreationOperation.java:65)
org.eclipse.jst.j2ee.internal.ejb.project.operations.EJBModu leCreationOperation.execute(EJBModuleCreationOperation.java: 45)
org.eclipse.wst.common.frameworks.operations.WTPOperation.do Run(WTPOperation.java:309)
org.eclipse.wst.common.frameworks.operations.WTPOperation$1. run(WTPOperation.java:233)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1702)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1722)
org.eclipse.wst.common.frameworks.operations.WTPOperation.ru n(WTPOperation.java:251)
org.eclipse.wst.common.frameworks.internal.ui.RunnableWithPr ogressWrapper.run(RunnableWithProgressWrapper.java:67)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
... 38 more
Re: ClassCastException trying to create EJB Project [message #77823 is a reply to message #77704] Sun, 27 February 2005 19:03 Go to previous message
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 38 more
Janne,
For EJB 2.0 project creation you need
http://www.eclipse.org/webtools/wst/components/ws/download_i nstructions_for_jars.html.
Although the build page says these jars are optional to enable web
services, it required for ejb 2.0 project creation. I have tried it both
without and with these jars and I see the same problem that you are
seing without these jars but once have the web services jars things are
working fine. We will look more into this issue in M4 to remove this
dependency.
- Vijay
Previous Topic:Deploy Eclipse Project - Java Web Start
Next Topic:Changing Context Root
Current Time: Mon Jul 14 15:09:06 EDT 2025
Powered by FUDForum. Page generated in 0.08593 seconds
