| Managed Build Change Notification [message #77681] |
Thu, 31 July 2003 15:30 |
Originally posted by: sevoy.rational.com
This is a message for anyone who has been using or testing the managed build
system. I have started a process of clean-up and rationalization.
Unfortunately, some changes that I submit over the next short while will
invalidate existing dot-cdtbuild project files. Yesterday I submitted such a
patch. If you download the build scheduled for August 1, your previous
models will not be understood by the managed builder. You have 2 choices
(hey, I'm not a tyrant):
1. You can create a new project, move the files over by hand and copy the
build settings over, or
2. Rename each instance of the following attributes in the dot-cdtbuild file
as specified here: optionRef->optionReference, toolRef->toolReference,
optionValue->listOptionValue, and optionEnum->enumeratedOptionValue
Ok, so maybe I am a tyrant after all.
In any case, there will be at least one more patch in the short-term that
may impact your projects. I apologize in advance, and will endeavour to
minimize the number of times you have to do this.
FUDForum. Page generated in 0.03981 seconds
