SampleClient TPTPAgent - Invalid Login Credentials [message #77635] |
Tue, 18 July 2006 10:10  |
Originally posted by: martin.schuetz.vmasch.at
I'm trying the TPTPAgent-Sample
( http://www.eclipse.org/tptp/platform/documents/newtechAC/jav adoc/TPTPAgent.java)
to connect to AC and to query all available and runnning agents. I'm using
the same data for the ConnectionInfo-object (host "127.0.0.1" and port
"10002") as in the "Profile"-window via Eclipse (where I can see AC with all
available agents).
Executing the sample, I get the following output:
Connecting to AC..
Error occurred while connecting to
127.0.0.1:org.eclipse.tptp.platform.execution.exceptions.Age ntControllerUnavailableException:
Error: Unable to connect to the Agent Controller.Invalid Login Credentials
I set the AC-network access mode to "ALL" and security enabled to "FALSE"
.... I also configured the AC and tried the connect(ConnectionInfo connInfo,
User user)-method, but it doesn't work.
I'm using Eclipse 3.2.0, TPTP 4.2 and the new technology Agent Controller.
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77856 is a reply to message #77732] |
Wed, 19 July 2006 12:30  |
Martin Schuetz wrote:
> I started my challenge via
> http://www.eclipse.org/tptp/platform/documents/newtechAC/jav adoc/overview-summary.html
> ... and I unfortunately mixed different versions.
> Now it works,
> Thanks!
I'm glad it works for you. I don't want to belabor the point, but I do
want to prevent anyone else going down this path... can you tell me more
explicitly how you got to the above so that I can bugzilla the
appropriate links to clean things up? I tried going through the main
Documentation link from TPTP, and then through Platform; then tried
through Platform link from TPTP, and then to Documentation... the
variations I tried didn't take me anywhere I saw any newtechAC references.
If you can recall the path you took, I'll try to get it cleaned up. Thanks.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
FUDForum. Page generated in 0.06992 seconds
