Home » Language IDEs » PHP Development Tools (PDT) » Auto-Complete takes too long
Auto-Complete takes too long [message #77618] Sat, 02 August 2008 14:33 Go to next message
Hi!
I Installed the latest Nightly Build of PDT 2.0 (20080801) with Eclipse
3.4 on OS X (10.4). If I type "$" to insert a variable in a PHP script,
eclipse calculates something (probably auto-complete) and does not react
on any interaction for about half a minute. Sometimes I get the following
error message:
Problem during Content Assist
The 'org.eclipse.ui.PHPCompletitionProposalComputer' proposal computer
from the 'org.eclipse.ui' plug-in did not complete normally. The extension
took too long to return from the 'computeCompletitionProposal()' operation.
To avoid this message, disable the 'org.eclipse.php.ui' plug-in or disable
the 'Type Proposals' category on the content assist preference page.
I tried several integration builds as well as lastest nightly builds. The
problem remains the same.
Another problem is, that marking of php source code takes very long,
sometimes I have to wait many seconds before I can mark a complete line of
source code by mouse.
Currently PDT is unusable in larger projects with code completition
enabled. If I disable it in preferences its fast, but this way a loose one
of the most important benefits of PDT.
Please tell me how I can provide you with more helpful debugging
information.
best regards
Andreas
Re: Auto-Complete takes too long [message #77666 is a reply to message #77618] Sat, 02 August 2008 21:25 Go to previous message
Andreas,
There has been a lot of discussion about this issue in this newsgroup as
well as bug postings about it. The developers are aware of the problem
and are working towards a resolution.
Reference: https://bugs.eclipse.org/bugs/show_bug.cgi?id=240826
Best thing to do for now is to disable auto-activation and only use
content assist when you have part of the variable already typed out. The
error listed below is happening mainly when there are too many matches.
Shawn Clark
Andreas Korthaus wrote:
> Hi!
> following error message:
> extension took too long to return from the
> disable the 'Type Proposals' category on the content assist preference
> page.
> The problem remains the same.
> of source code by mouse.
> one of the most important benefits of PDT.
> information.
> best regards
> Andreas
Previous Topic:Installing on Eclipse 3.4
Next Topic:Can't install by Update - wst.web_ui dependency
Current Time: Sun Jul 27 03:08:43 EDT 2025
Powered by FUDForum. Page generated in 0.04651 seconds
