Home » Archived » Visual Editor (VE) » Trouble with SWT Table/TableColumn
Trouble with SWT Table/TableColumn [message #77597] Mon, 17 January 2005 22:04 Go to next message
Originally posted by: carmen.blackdirt.com
I added a Table to a shell visually with no issue. I understand how I
would add columns and in source mode. I see the TableColumn in the
Palette, but can not add it to the table. I may be missing something, but
could not find an answer in the help.
Carmen
Re: Trouble with SWT Table/TableColumn [message #77613 is a reply to message #77597] Mon, 17 January 2005 23:07 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Carmen,
Currently the VE lacks the ability to graphically manipulate SWT table
columns. However you can drop the TableColumn onto the Table in the
Java Beans view. You can reorder your dropped columns by dragging and
dropping the columns on the tree.
Hope this helps,
- Jeff
> but could not find an answer in the help.
> Carmen
Re: Trouble with SWT Table/TableColumn [message #77738 is a reply to message #77613] Tue, 18 January 2005 20:38 Go to previous message
Thank you. I appreciate it
Re: Trouble with SWT Table/TableColumn [message #604675 is a reply to message #77597] Mon, 17 January 2005 23:07 Go to previous message
Carmen,
Hope this helps,
- Jeff
> Carmen
Re: Trouble with SWT Table/TableColumn [message #604724 is a reply to message #77613] Tue, 18 January 2005 20:38 Go to previous message
Previous Topic:[JEM][OT] Why not use org.eclipse.jdt.debug?
Next Topic:empty palette
Current Time: Thu Jul 17 20:47:43 EDT 2025
Powered by FUDForum. Page generated in 0.26517 seconds
