Home » Archived » M2M (model-to-model transformation) » [ATL]UML 2 BPEL transformation
[ATL]UML 2 BPEL transformation [message #77592] Thu, 27 March 2008 00:44 Go to next message
Originally posted by: hr_mi.live.cn
Hi ,everyone :
I want to transform a class diagram to bpel , it is defined like this:
<<Data>>
purchaseOrder
attributes
customerID:String
orderID:String
orderItem:OrderItem
operations
classes
and the WSDL is defined as following:
Corresponding WSDL fragment:
<element name="purchaseOrder">
<complexType>
<sequence>
<element name="customerID" nillable ="true" type="xsd:string" />
<element name="orderI" nillable ="true" type="xsd:string" />
<element name="avaliability" nillable ="true" type="xsd:string"/>
</sequence>
</complexType>
</element>
<wsdl:message name="purchaseOrderMessage">
<wsdl:part name="parameters" element="tns:purchaseOrder" />
<wsdl:part name="attribute1" type=" xsd:string" />
</wsdl:message>
I am a new learner about this , who can help me make a rue for this
transformation ?
Thanks very much.
Re: [ATL]UML 2 BPEL transformation [message #77692 is a reply to message #77592] Thu, 27 March 2008 09:39 Go to previous messageGo to next message
--------------090005000303070005030902
Content-Type: text/plain; charset=GB2312
unique a
Re: [ATL]UML 2 BPEL transformation [message #77792 is a reply to message #77692] Fri, 28 March 2008 04:27 Go to previous message
William Piers 写道:
> Hello,
> unique a écrit :
>> Hi ,everyone :
>> <<Data>>
>> purchaseOrder
>> attributes
>> customerID:String
>> orderID:String
>> orderItem:OrderItem
>> operations
>> classes
>> <complexType>
>> <sequence>
>> </sequence>
>> </complexType>
>> </element>
>> </wsdl:message>
>> transformation ?
> The best way to learn is to try ;-) . I strongly advise you to watch
> some examples, for example in those pages :
> http://www.eclipse.org/m2m/atl/usecases/
> http://www.eclipse.org/m2m/atl/atlTransformations/
> You will find many UML2<something> examples. Then if you encounter
> problems, do not hesitate to ask here.
>> Thanks very much.
> Best regards,
> William
Thanks for your advices !
I will try to do it best!
Previous Topic:ATL transformation
Next Topic:[AM3] Not bundled with ATL?
Current Time: Thu Nov 06 23:03:50 EST 2025
Powered by FUDForum. Page generated in 0.03968 seconds
