Home » Newcomers » Newcomers » Trying to add "installed Servers" Tomcat version 3.1
Trying to add "installed Servers" Tomcat version 3.1 [message #77586] Mon, 13 June 2005 19:42 Go to next message
Originally posted by: tjones.brainshield.com
I have:
Version: 3.1.0
Build id: I20050401-1645
I can't even get a dialog box to come up to chose the possible servers
after selecting:
Windows>Preferences>Servers>Installed servers; I get this error.
Error 2005-06-13 17:38:07.72 Unhandled event loop exception
java.lang.NoClassDefFoundError: org/eclipse/wst/server/core/ITaskModel
org.eclipse.wst.server.ui.internal.RuntimePreferencePage.sho wWizard(RuntimePreferencePage.java:349)
org.eclipse.wst.server.ui.internal.RuntimePreferencePage$2.w idgetSelected(RuntimePreferencePage.java:136)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: Trying to add "installed Servers" Tomcat; Eclipse version 3.1 [message #77861 is a reply to message #77586] Tue, 14 June 2005 14:54 Go to previous message
Subject should read Eclipse version 3.1
Is this a classpath problem?
Tad wrote:
> I have:
> Version: 3.1.0
> after selecting:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Updataing from 3.1M7 to 3.1RCn
Next Topic:How to enable assert statements?
Current Time: Thu Nov 20 19:28:02 EST 2025
Powered by FUDForum. Page generated in 0.07112 seconds
