Home » Eclipse Projects » OSEE » OSEE Component Specifications
OSEE Component Specifications [message #6953] Tue, 29 April 2008 10:08 Go to next message
A more detailed description of the long term components proposed for
OSEE can be seen at http://www.eclipse.org/osee/components.php. This
does not include the changes that will come about with further
integration with ORMF and is certainly not a comprehensive list.
Instead, it will dynamically change as we continue our collaboration.
Re: OSEE Component Specifications [message #6976 is a reply to message #6953] Thu, 01 May 2008 10:34 Go to previous message
Thanks for the pointer, Don. Just a quick note that your hyperlink has
a trailing "." at the end which prevents the page from being accessed.
It should be http://www.eclipse.org/osee/components.php
Cheerio,
B.
                                  Barbara Rosi-Schwartz
                   Etish Limited [http://www.etish.org]
Blog: http://www.brs4etish.blogspot.com
 /  o,o  \       The proud parents of Useme
 |) ::: (|       The Open Requirements Management Tool
====w=w====      [https://useme.dev.java.net]
Re: OSEE Component Specifications [message #569938 is a reply to message #6953] Thu, 01 May 2008 10:34 Go to previous message
Cheerio,
B.
Previous Topic:OSEE Component Specifications
Next Topic:Collaboration Inquiry and Civil Engineering
Current Time: Fri Jul 18 23:25:29 EDT 2025
Powered by FUDForum. Page generated in 0.03269 seconds
