| autoconf/automake support [message #77411] |
Wed, 30 July 2003 00:08  |
Originally posted by: mw.colastic.net
I've been searching around for automake/autoconf support in the CDT.
There seems to be mentions of it here and there, but no definitive
answers as to what versions (if at all) it exists in and how to use it.
Basically, I have project in CVS that I'd like to be able to check
out, and then have Eclipse run configure and then make for the build
process. Being able to supply options to configure would be a bonus.
Does this exist now? Are there plans for it to exist eventually? If
someone could give me a very general idea about where to start coding
this as a plugin or something I might be able to give it a shot (I have
zero knowledge of coding for the eclipse platform, but I'm pretty good
with java coding in general).
Matt Wallace
| Re: autoconf/automake support [message #77577 is a reply to message #77411] |
Wed, 30 July 2003 21:19  |
There was some talks from folks from Redhat but basically
they redirected there resources to GCJ and to be able to compile
Eclipse.
What don't you give eclipse a chance 8-), it is not that hard
to learn and maybe ... your first plugin.
FUDForum. Page generated in 0.04115 seconds
