| Home » Eclipse Projects » Equinox » Startup order effecting servlet registration classloader
 Goto Forum:|
| Startup order effecting servlet registration classloader [message #77396] | Thu, 16 November 2006 20:55  |  |
| Eclipse User  |  |  |  |  | Hey,
 I have a servlet that I'm trying to run under equinox but it's behaving
 differently on two separate servers.
 The difference between the two seems to be with the startup ordering of
 the org.eclipse.equinox.servlet.bridge.http bundle and the servlet bundle.
 Depending on which one starts first the servlet will either be
 registered with a
 org.eclipse.core.runtime.internal.adaptor.ContextFinder class loader or
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.
 The ContextFinder if the servlet bundle is started first, and
 DefaultClassLoader if the bridge is started first.
 It appears that the servlet can't find some resources when starting with
 the DefaultClassLoader but it can when started with the ContextFinder so
 it's running into problems.
 Is this the correct way for the class loaders to work in this situation?
 Or is the servlet doing something it shouldn't?
 Shaun
 PS. I guess I'll try the latest equinox builds to see if they're different
| Re: Startup order effecting servlet registration classloader [message #77747 is a reply to message #77452] | Mon, 20 November 2006 18:47   |  |
| Eclipse User  |  |  |  |  | Hey Simon,
 Something setting the context class loader, but it's not me.
 At the moment I'm using the embedded Jetty service.
 org.eclipse.equinox.http.registry (dev.eclipse.org/HEAD),
 org.eclipse.equinox.http.servlet (dev.eclipse.org/HEAD),
 org.eclipse.equinox.jetty.http (dev.eclipse.org/HEAD) and
 org.mortbay.jetty (dev.eclipse.org/v5_1_11).
 And I have two scenarios depending on the start order:
 1. Doesn't work when I need the resources later
 org.eclipse.equinox.http.registry.internal.Activator tracks PackageAdmin
 and IExtensionRegistry services and when it has both creates a
 HttpServiceTracker
 org.eclipse.equinox.http.registry.internal.Activator.addingS ervice is
 triggered (twice) and creates a HttpServiceTracker
 org.eclipse.equinox.http.servlet.internal.Activator starts
 HttpServiceProxy by registering any HttpServices is knows about (there
 are none)
 org.eclipse.equinox.jetty.http.internal.Activator constructs and starts
 new HttpServer
 HttpServiceTracker.addingService(for HttpService) is triggered and
 creates a new ServletManager (and HttpContextManager and ResourceManager)
 ServletManager.added(IExtension) is triggered which creates a new
 ServletRegistration with a
 org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader as the
 registeredContextClassLoader
 2. Does work when I need the resources
 new HttpServer
 HttpServiceTracker
 HttpServiceProxy by registering any HttpServices is knows about (this
 time there is one)
 org.eclipse.core.runtime.internal.adaptor.ContextFinder as the
 So something in there is changing the thread context class loader
 I don't know if this is the expected behaviour.
 As for the code that's trying to access the resources, it's using JAXB
 with the JAXB generated classes in one bundle and another bundle trying
 to access these classes with JAXBContext.newInstance(contextPath), for
 example
 client.servlet bundle contains a servlet that uses
 JAXBContext ctx = JAXBContext.newInstance("client.bind");
 and has a required dependency in the manifest for client.bind
 client.bind bundle contains the JAXB generated classes, including
 client.bind.ObjectFactory.class (which is the resource the
 JAXB.newInstance() fails on)
 JAXBContext.newInstance uses the thread context class loader specified
 in the servlet registration to find the ObjectFactory class, which fails
 with the DefaultContextLoader but succeeds with the ContextFinder.
 Not sure which class loader is supposed to be used, or if JAXB is
 supported in this way.
 Shaun
 Simon Kaegi wrote:
 > Hi Shaun,
 > That sounds strange -- you shouldn't have to mess with the start levels and
 > unless you're explicitly setting a thread context class loader the
 > ContextFinder shouldn't really enter into the picture.
 > Are you running in an appserver (e.g. with bridge.war) or using the embedded
 > Jetty HttpService?
 > You mentioned updating to the latest code and that's probably a good idea.
 > There's a couple of documents on http://www.eclipse.org/equinox/server that
 > should help setting up.
 > If you're still having problems can you tell a bit more about how your
 > Servlet is looking up resources.
 > -Simon
 > "Shaun Forbes" <sforbes@sforbes.myip.org> wrote in message
 > news:ejj7tl$cdi$1@utils.eclipse.org...
 >> I've found that putting org.eclipse.equinox.jetty.http to start level 2,
 >> so it starts before org.eclipse.equinox.servlet.bridge.http stops the
 >> problem, but I'm not convinced that the displayed behaviour is correct.
 >> Cheers
 >> Shaun Forbes wrote:
 >>> Hey,
 > bundle.
 >>> registered with a
 >>> Cheers,
 >>> Shaun
 > different
| Re: Startup order effecting servlet registration classloader [message #77764 is a reply to message #77747] | Mon, 20 November 2006 22:19   |  |
| Eclipse User  |  |  |  |  | Originally posted by: skaegi.sympatico.ca
 Thanks Shaun!
 Great job tracking this down. That's not the intended behaviour and is
 definitely a bug.
 The TCCL should be restored to ContextFinder regardless of start order.
 I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=165273 to track
 the issue.
 -Simon
 news:45623E97.3080909@sforbes.myip.org...
 > Hey Simon,
 > HttpServiceTracker
 > are none)
 > new HttpServer
 > new HttpServer
 > HttpServiceTracker
 > time there is one)
 > example
 > Cheers,
 > Shaun
 > Simon Kaegi wrote:
 > > Hi Shaun,
 and
 embedded
 > > Jetty HttpService?
 idea.
 that
 > > -Simon
 2,
 > >> Cheers
 > >> Shaun Forbes wrote:
 > >>> Hey,
 behaving
 of
 > > bundle.
 > >>> registered with a
 or
 with
 so
 situation?
 > >>> Cheers,
 > >>> Shaun
 > > different
| Re: Startup order effecting servlet registration classloader [message #77891 is a reply to message #77764] | Wed, 22 November 2006 22:58   |  |
 Fixed in org.eclipse.equinox.http.jetty HEAD.
 Thanks Shaun
 "Simon Kaegi" <skaegi@sympatico.ca> wrote in message
 news:ejtr7m$fa7$1@utils.eclipse.org...
 > Thanks Shaun!
 > definitely a bug.
 > the issue.
 > -Simon
 > > Hey Simon,
 > > HttpServiceTracker
 > > are none)
 > > new HttpServer
 ResourceManager)
 > > new HttpServer
 > > HttpServiceTracker
 > > time there is one)
 ResourceManager)
 > > example
 > > Cheers,
 > > Shaun
 > > Simon Kaegi wrote:
 > > > Hi Shaun,
 levels
 > and
 > embedded
 > > > Jetty HttpService?
 > idea.
 > that
 > > > -Simon
 > 2,
 correct.
 > > >> Cheers
 > > >> Shaun Forbes wrote:
 > > >>> Hey,
 > behaving
 > of
 > > > bundle.
 > > >>> registered with a
 > or
 > with
 ContextFinder
 > so
 > situation?
 > > >>> Cheers,
 > > >>> Shaun
 > > > different
| Re: Startup order effecting servlet registration classloader [message #77906 is a reply to message #77891] | Thu, 23 November 2006 00:53  |  |
| Eclipse User  |  |  |  |  | Looks good, thanks for the quick turn around.
 Cheers
 > Thanks Shaun
 >> Thanks Shaun!
 >> definitely a bug.
 >> the issue.
 >> -Simon
 >>> Hey Simon,
 >>> HttpServiceTracker
 >>> are none)
 >>> new HttpServer
 > ResourceManager)
 >>> new HttpServer
 >>> HttpServiceTracker
 >>> time there is one)
 > ResourceManager)
 >>> example
 >>> Cheers,
 >>> Shaun
 >>> Simon Kaegi wrote:
 >>>> Hi Shaun,
 > levels
 >> and
 >> embedded
 >>>> Jetty HttpService?
 >> idea.
 >> that
 >>>> -Simon
 >> 2,
 > correct.
 >>>>> Cheers
 >>>>> Shaun Forbes wrote:
 >>>>>> Hey,
 >> behaving
 >> of
 >>>> bundle.
 >>>>>> registered with a
 >> or
 >> with
 > ContextFinder
 >> so
 >> situation?
 >>>>>> Cheers,
 >>>>>> Shaun
 >>>> different
 Current Time: Fri Oct 31 05:50:43 EDT 2025
 Powered by FUDForum . Page generated in 0.51884 seconds |
