| dynamically loaded classes missing from results [message #77358] | Wed, 12 July 2006 23:34  |  |
| Eclipse User  |  |  |  |  | When I profile my application, classes loaded dynamically (using a Class.forName, and then a using the getConstructor and newInstance) are
 not appearing in the results. I'm pretty sure that they are not being
 filtered out, and classes that are in the same package as the
 dynamically loaded classes are appearing.
 Is it possible that there is a setting or a special way of loading
 classes that I need to use?
 Any help is greatly appreciated!
 Thank you,
 -- Scott
| Re: dynamically loaded classes missing from results [message #77374 is a reply to message #77358] | Thu, 13 July 2006 02:33  |  |
| Eclipse User  |  |  |  |  | Scott A. Hendrickson wrote: > When I profile my application, classes loaded dynamically (using a
 > Thank you,
 > -- Scott
 Scott,
 Can you give us more information about the environment you use (Eclipse
 version, TPTP version, JRE version) and the nature of your application?
 I have a small test application that uses reflection and the methods I
 execute through reflection appear in the profiling results, so I can't
 really reproduce the behavior you describe.
 If you are using a Java 5 (1.5) VM, you may want to check the new JVMTI
 Profiler available as a Tech Preview in TPTP 4.2 (binaries and
 documentation are available on the TPTP 4.2 download page). This new
 profiler does not rely on VM generated events to track method entry and
 exit, but modifies the byte code of all running classes (including
 "reflected" classes) in order to do this tracking. Therefore, it may
 work better with code that heavily uses reflection.
 HTH
 Asaf
 Asaf Yaffe
 Eclipse TPTP Committer, Platform Project (JVMTI Profiler)
FUDForum. Page generated in 0.03648 seconds
