Home » Language IDEs » Java Development Tools (JDT) » Show matching brace/paren?
Show matching brace/paren? [message #77282] Thu, 17 July 2003 14:01 Go to next message
Originally posted by: sean.bedroom.seanleblancathome.net
How can I show the matching paren/brace in Eclipse?
Sean
Re: Show matching brace/paren? [message #77298 is a reply to message #77282] Thu, 17 July 2003 14:23 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
Window->Preferences, Java->Editor->Appearance Tab, "Highlight matching
brackets"
-tom
> Sean
Re: Show matching brace/paren? [message #77346 is a reply to message #77298] Thu, 17 July 2003 15:47 Go to previous messageGo to next message
> brackets"
> -tom
Also, Ctrl+Shift+P will take you to the matching bracket (if you are
using the default keybindings).
Jeff
Re: Show matching brace/paren? [message #77710 is a reply to message #77346] Fri, 18 July 2003 08:46 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Thu, 17 Jul 2003 22:41:12 +0000 (UTC), Sean
<sean@bedroom.seanleblancathome.net> a écrit :
>Thanks, works like a champ. Well, except for one thing that I noticed. On a
>static block, I noticed ctrl-shift-p goes forward, but it doesn't go backward.
>No biggie, but I thought it'd be worthwhile to say something.
Open a bug report for this against JDT/UI.
Olivier
Re: Show matching brace/paren? [message #77788 is a reply to message #77346] Fri, 18 July 2003 10:24 Go to previous message
Sean wrote:
> Jeff Hunter <jxh106@po.cwru.edu> wrote:
>>>brackets"
>>>-tom
>>Jeff
> I'm using 2.1.0.
Works for me with 2.1.1.
Jeff
Previous Topic:Verification in time of project
Next Topic:Problems when using Eclipse strictly as a debugger
Current Time: Thu Nov 06 15:39:26 EST 2025
Powered by FUDForum. Page generated in 0.03974 seconds
