Home » Archived » Test and Performance Tools Platform (TPTP) » commons-logging.jar not loaded
commons-logging.jar not loaded [message #77249] Wed, 12 July 2006 06:24 Go to next message
Originally posted by: prince.pajero.gmail.com
I run TPTP Junit plugin test for my plugin. Here is the setup.
Plugin xyzlib contains the commons-logging.jar
Plugin abcPlugin has some simple code which uses classes provided by
common-logging.jar
In plugin xyzlib I've exported the commons-logging.jar from the Project
Properties sheet. I've also added the jar to the Classpath in the
Runtime tab of the Manifest editor. Also, I've exported the packages to
all downstream plugins.
Now my plugin abcPlugin has some (plain) Junit tests, which I can run
using Run > Run as Junit Plugin Test. There are no problems and my code
can find the classes from the commons-logging.jar
Problem is when I Import the same tests TPTP Junit Plugin tests and try
to run then my code throws a Runtime NoClassDefFoundException.
I tried to debug and found that in BundleLoader.class, in the method:-
Class findClass(String name, boolean checkParent) throws
ClassNotFoundException
after these lines:-
// 4) search the required bundles
source = findRequiredSource(pkgName);
the source variable:-
source > supplier > loader > classloader > classpathentries
has the entry for commons-logging.jar in case of Junit Plugin Test
BUT
does not have any entry in case of TPTP Junit Plugin Test.
Re: commons-logging.jar not loaded [message #77265 is a reply to message #77249] Wed, 12 July 2006 06:30 Go to previous messageGo to next message
Forgot to add this:-
I'm using eclipse 3.1.2 with TPTP 4.1.0.1, Sun Java 1.5 OS is FC3-linux
Also, TPTP uses the commons-logging.jar itself, so it might be causing
some conflict and hence the commons-logging.jar is not loaded by the
class loader when my code requests it.
Are these any useful links:-
http://www.qos.ch/logging/classloader.jsp
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. hyades.test.doc.user/tasks/tdeploymentGroundRules.htm
For the second link, the Excluded Libraries topic seems interesting. But
I have no idea why isn't this 'issue' resolved.
> common-logging.jar
> after these lines:-
> BUT
Re: commons-logging.jar not loaded [message #77280 is a reply to message #77265] Wed, 12 July 2006 06:41 Go to previous messageGo to next message
The plugin org.apache.jakarta_commons_logging has the
commons-logging.jar already, which I guess is causing the problem
>> common-logging.jar
>> Project Properties sheet. I've also added the jar to the Classpath in
>> the Runtime tab of the Manifest editor. Also, I've exported the
>> packages to all downstream plugins.
>> code can find the classes from the commons-logging.jar
>> try to run then my code throws a Runtime NoClassDefFoundException.
>> after these lines:-
>> BUT
Re: commons-logging.jar not loaded [message #77296 is a reply to message #77280] Wed, 12 July 2006 07:29 Go to previous messageGo to next message
I made my plugin dependent on org.apache.jakarta_commons_logging and
evrything worked fine. But this is not how I want to do it. I want the
commons-logging.jar api to be available through my plugin only.
Please Help !!
>> But I have no idea why isn't this 'issue' resolved.
>>> common-logging.jar
>>> after these lines:-
>>> BUT
Re: commons-logging.jar not loaded [message #77329 is a reply to message #77249] Wed, 12 July 2006 11:45 Go to previous messageGo to next message
Hi Prince,
This is not related to the org.apache.jakarta_commons_logging plugin
that ships with TPTP. This is a defect in that the TPTP execution harness
is not deploying the commons-logging.jar from the abcPlugin. You can
confirm this by checking if the commons-logging.jar is in the <user temp
directory>/<user name>/ directory tree. Your solution (making the abcPlugin
dependency on org.apache.jakarta_commons_logging plugin) will solve the
problem or you can create an artifact (Help >> Help Contents >> Testing
applications >> Testing with JUnit >> Running a JUnit test remotely) with
the commons-logging.jar set on the CLASSPATH property of the artifact. That
said, these are only suggested work-arounds. Please open a TPTP defect
( https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=T PTP) for this
problem.
Paul
"Prince Singh" <prince.pajero@gmail.com> wrote in message
news:e92ijc$mk4$1@utils.eclipse.org...
> common-logging.jar
> after these lines:-
> BUT
Re: commons-logging.jar not loaded [message #77388 is a reply to message #77329] Thu, 13 July 2006 05:27 Go to previous messageGo to next message
Thanks for confirming the bug.
As suggested by you, A bug is being opened at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150484
I've set the severity to major. You may modify as you know better about
the severity.
Paul Slauenwhite wrote:
> Hi Prince,
> problem.
> Paul
>> common-logging.jar
>> after these lines:-
>> BUT
Re: commons-logging.jar not loaded [message #77520 is a reply to message #77296] Mon, 17 July 2006 08:17 Go to previous message
I tried with eclipse 3.2.0 and tptp 4.2.0 the problem is not there.
> Please Help !!
>>> causing some conflict and hence the commons-logging.jar is not loaded
>>> by the class loader when my code requests it.
>>>> common-logging.jar
>>>> in the Runtime tab of the Manifest editor. Also, I've exported the
>>>> run using Run > Run as Junit Plugin Test. There are no problems and
>>>> my code can find the classes from the commons-logging.jar
>>>> after these lines:-
>>>> BUT
Previous Topic:about the old and new agent controller
Next Topic:line coverage tool: library piLLCAgent
Current Time: Wed Dec 03 01:31:21 EST 2025
Powered by FUDForum. Page generated in 0.05830 seconds
