Home » Eclipse Projects » Eclipse Platform » Inspect/Display Grayed Out (3.0 M1)
Inspect/Display Grayed Out (3.0 M1) [message #77185] Tue, 17 June 2003 20:16 Go to next message
Originally posted by: gss.cybermesa.com
When I'm paused in the Java debugger, the contextual menu items
"Watch", "Inspect", "Display", and "Execute" are always grayed out,
even when I have an expression highlighted. They work fine in the
release version of 2.1. I don't see a bug report for this yet, so I
wonder if it's just me who is having the problem.
Re: Inspect/Display Grayed Out (3.0 M1) [message #77204 is a reply to message #77185] Tue, 17 June 2003 20:22 Go to previous messageGo to next message
Arghh, in prototypical bad form, I posted while I still had one
small thing in mind to try, and it works when I try it. It seems
that the menu items are not enabled when a variable is highlighted,
as it was in 2.1. My apologies for answering my own post...
In a related note, are "Inspect" and "Display" extremely slow for
others? Perhaps they execute without the benefit of the JIT.
Re: Inspect/Display Grayed Out (3.0 M1) [message #79284 is a reply to message #77204] Fri, 20 June 2003 11:54 Go to previous message
More on the behavior I was describing: if I have just the characters of
a variable highlighted, the menus are grayed out. If I have even a single
extra space highlighted, the menus are enabled. For example, say I'm in
a method with the debugger paused, and the method's class has an instance
variable "foo" in addition to a large number of other instance variables.
To see the contents of foo, I could just open "this" in the variables
view, but to conserve screen real estate (i.e. not have to see all the
other instance variables of "this"), I normally would just highlight
"foo" and select "Inspect". As of 3.0 M1, when "foo" is highlighted, the
menu items are grayed out. However, if I highlight " foo" or "foo ", the
menu items are enabled and I can inspect foo.
So, before I add a bug report, I'd like to ask what the intended behavior
is. My view is that the menu items should be available when any expression
is highlighted, and that includes an instance variable (e.g. "foo"), which
after all, is just a shorthand for the expression "this.foo".
Previous Topic:Re: Eclipse Help hyperlinks do nothing - reinstall Eclipse or ??
Next Topic:External Tools Plugin in 2.1.1 and 3.0 M1
Current Time: Sat Oct 25 21:18:20 EDT 2025
Powered by FUDForum. Page generated in 0.04546 seconds
