Home » Language IDEs » ServerTools (WTP) » Set Environment Variables through Eclipse
Set Environment Variables through Eclipse [message #77157] Fri, 25 February 2005 18:14 Go to next message
Originally posted by: wmohamud.gmail.com
I am attempting to set environment variables through the Eclipse 3.0 IDE.
I have configured a Tomcat 3.2.3 server with a 1.4.2 JDK (unfortunately I
have to use this version of Tomcat). However, when I try to run my app
from Eclipse (Run on Server), the environment variables I set in the
config file (Tomcat.bat) under the Tomcat installation is ignored.
Instead, Eclipse seems to have its own Tomcat configuration that it uses.
Any help would be much appreciated.
Re: Set Environment Variables through Eclipse [message #83358 is a reply to message #77157] Mon, 14 March 2005 08:29 Go to previous message
Hi Warsame,
The Tomcat batch files are never used directly. You can set the environment
variables before starting eclipse, or via the Eclipse Launch Configuration
dialog. Go to the Debug perspective, and then Run > Run... (there are
several other ways of getting here too) Find the correct Tomcat launch in
the list on the left, and then you can change the specific settings of the
launch in the right-hand pane.
Previous Topic:How to set Classpath and JVM parameters
Next Topic:Problems occurred when invoking code from plug-in: "org.eclipse.jface"
Current Time: Tue Jul 22 02:38:33 EDT 2025
Powered by FUDForum. Page generated in 0.03474 seconds
