| copy xsd type definition from one schema to another [message #77145] |
Wed, 18 February 2009 12:08  |
Originally posted by: jacek.pospychala.pl.ibm.com
hi,
I'm trying to copy a XSDTypeDefinition from one schema to another with
following code:
XSDSchema dstSchema = // destination schema
XSDSchema srcSchema = // source schema
XSDTypeDefinition srcType = srcSchema.getTypeDefinitions().get(0);
// 1. copy schema element
XSDTypeDefinition dstType = (XSDTypeDefinition)
srcType.cloneConcreteComponent(true, true);
// 2. copy DOM element
Element dstElement = (Element)
dstSchema.getDocument().importNode(newType.getElement(), true);
dstType.setElement(dstElement);
// 3. put copied element to new schema
srcSchema.getContents().add(dstType);
But this way I seem to loose sync between schema model and DOM model of
copied XSDTypeDefinition.
When I do only 1., then some DOM elements are missing.
What's the correct way to do the copy?
THanks in advance!
Jacek
| Re: copy xsd type definition from one schema to another [message #77192 is a reply to message #77145] |
Thu, 19 February 2009 04:16  |
ok, I see earlier topic "How to clone annotations".
Jacek Pospychala pisze:
> hi,
> following code:
> THanks in advance!
> Jacek
| Re: copy xsd type definition from one schema to another [message #604036 is a reply to message #77145] |
> hi,
> following code:
> THanks in advance!
> Jacek
FUDForum. Page generated in 0.04247 seconds
