Home » Language IDEs » ServerTools (WTP) » Error J2EE Perspective
Error J2EE Perspective [message #77114] Fri, 25 February 2005 16:09 Go to next message
Originally posted by: ceeneel.gmail.com
I am using Integration Build I20050224,
eclipse.buildId=I20050219-1500
java.version=1.5.0_01
Command-line arguments: -os win32 -ws win32 -arch x86
Errors:
1) Empty tree node after "Other Projects"
2) Following error occuring when clicked on <project name> under "Dynamic
Web Projects"
!ENTRY org.eclipse.jface 4 2 2005-02-25 16:07:49.133
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/wst/wsdl/internal/util/WSDLResourceImpl
org.eclipse.jst.j2ee.internal.webservice.helper.WSDLServiceH elperImpl.isWSDLResource(WSDLServiceHelperImpl.java:176)
org.eclipse.jst.j2ee.internal.actions.OpenJ2EEResourceAction .isWsdlInstance(OpenJ2EEResourceAction.java:412)
org.eclipse.jst.j2ee.internal.actions.OpenJ2EEResourceAction .updateSelection(OpenJ2EEResourceAction.java:349)
org.eclipse.ui.actions.BaseSelectionListenerAction.selection Changed(BaseSelectionListenerAction.java:124)
org.eclipse.jst.j2ee.navigator.internal.J2EEActionProvider.s etActionContext(J2EEActionProvider.java:80)
org.eclipse.wst.common.navigator.views.NavigatorActionServic e.fillActionBars(NavigatorActionService.java:214)
org.eclipse.wst.common.navigator.views.CommonNavigatorManage r.selectionChanged(CommonNavigatorManager.java:97)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:163)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1015)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:161)
3)I am getting following error messages when opening j2ee Perspective.
!ENTRY org.eclipse.core.runtime 4 2 2005-02-25 15:59:55.632
!MESSAGE Plug-in "org.eclipse.wst.wsdl" was unable to instantiate class
"org.eclipse.wst.wsdl.WSDLPlugin$Implementation".
!STACK 0
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:415)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:363)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:332)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:28)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:327)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:276)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:331)
at ......
Re: Error J2EE Perspective [message #77389 is a reply to message #77114] Sat, 26 February 2005 12:28 Go to previous messageGo to next message
Hi Yogesh,
The error looks like one of the dependencies from the Web Services
components. Have you downloaded the Web Services jars from
http://www.eclipse.org/webtools/wst/components/ws/download_i nstructions_for_jars.html ?
Please verify that you have downloaded these extra jars, and if the
problem still exists, then open a defect to track the issue:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols .
Thanks!
Kind Regards,
Michael D. Elder
"Yogesh" <ceeneel@gmail.com> wrote in message
news:cvo475$nlp$1@www.eclipse.org...
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Errors:
> Web Projects"
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
:1015)
> !STACK 0
> at
sorImpl.java:39)
> at
> at
> at
> at
r.java:332)
> at
r.java:28)
> at
xtImpl.java:995)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
xtImpl.java:970)
> at
ava:327)
> at
..java:276)
> at
assLoader.java:110)
> at
oader.java:331)
> at ......
Re: Error J2EE Perspective [message #77598 is a reply to message #77389] Sun, 27 February 2005 04:14 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Michael D. Elder wrote:
>Hi Yogesh,
> Thanks!
>Kind Regards,
>Michael D. Elder
I had exactly the same error with Eclipse 3.1 M5a and WTP 1.0 M3 when
opening J2EE perspective. Does this mean that opening J2EE perspective
has a dependency in some webservices jar files?
Thanks in advance,
Chemi.
Re: Error J2EE Perspective [message #77628 is a reply to message #77598] Sun, 27 February 2005 05:25 Go to previous message
Fixed. To avoid that problem you need wsdl4j.
Download it from:
http://prdownloads.sourceforge.net/wsdl4j/wsdl4j-bin-1.4.zip ?download
and copy its two JAR files into:
<wtpInstallDirectory>/eclipse/plugins/org.eclipse.wst.wsdl_1.0.0/lib/
Hope it helps,
Chemi.
Previous Topic:Configure Eclipse for Tomcat5.0
Next Topic:Deploy Eclipse Project - Java Web Start
Current Time: Sun Aug 31 22:10:09 EDT 2025
Powered by FUDForum. Page generated in 0.39469 seconds
