Home » Modeling » GMF (Graphical Modeling Framework) » Exception when deleting edge
Exception when deleting edge [message #77000] Mon, 13 November 2006 01:57 Go to next message
when I delete an edge within my model, I get an ExecutionException
caused by an IllegalArgumentException in java.util.List (I attached the
stack trace below).
I've read the "Exception when deleting node" thread and, thanks to
Cherie's advice, added an according breakpoint. I can see that there is
a DeleteFromModelAction envolved, and the command seems to be a
CompositeTransactionalCommand containing a CompositeCommand which
(finally) contains an AbstractEditHelper$1 and a DeleteCommand.
Unfortunately, this doesn't help me too much -looking into the
DeleteCommand didn't show anything unexpected (at least for me :-) ).
I'm using the current Callisto versions. Any idea on what's going on?
Thanks in advance,
Chris
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:517)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:193)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.exe cute(DiagramAction.java:139)
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doR un(DiagramAction.java:101)
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:358)
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(A ctionManager.java:223)
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.runWithEvent(AbstractActionHandler.java:376)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.IllegalArgumentException: fromIndex(1) > toIndex(0)
at java.util.SubList.<init>(Unknown Source)
at java.util.RandomAccessSubList.<init>(Unknown Source)
at java.util.AbstractList.subList(Unknown Source)
org.eclipse.emf.transaction.impl.ReadWriteValidatorImpl$Noti ficationTree.collectNotifications(ReadWriteValidatorImpl.jav a:398)
org.eclipse.emf.transaction.impl.ReadWriteValidatorImpl$Noti ficationTree.collectNotifications(ReadWriteValidatorImpl.jav a:401)
org.eclipse.emf.transaction.impl.ReadWriteValidatorImpl$Noti ficationTree.collectNotifications(ReadWriteValidatorImpl.jav a:369)
org.eclipse.emf.transaction.impl.ReadWriteValidatorImpl.getN otificationsForPostcommit(ReadWriteValidatorImpl.java:184)
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain.postcommit(DiagramEditingDomainFac tory.java:179)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:469)
org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:524)
org.eclipse.emf.transaction.impl.TransactionImpl.rollback(Tr ansactionImpl.java:417)
org.eclipse.emf.workspace.AbstractEMFOperation.rollback(Abst ractEMFOperation.java:442)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:158)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
... 34 more
Re: Exception when deleting edge [message #77498 is a reply to message #77000] Tue, 14 November 2006 10:35 Go to previous message
Chris,
The bottom of the stack trace that you sent shows that the
AbstractEMFOperation is being 'rolled back'. This is probably happening
because there was another exception thrown during the execution of one
of the commands. Did you try debugging the execution of the commands to
make sure no exceptions are thrown then? Put a breakpoint in the
DeleteCommand's execute method.
Hope this helps.
- Cherie
chris wrote:
> stack trace below).
> Thanks in advance,
> Chris
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
Previous Topic:Need to turn off stuff - How ?
Next Topic:Multiple diagrams
Current Time: Sun Aug 31 11:18:03 EDT 2025
Powered by FUDForum. Page generated in 0.03410 seconds
