Home » Archived » Visual Editor (VE) » newbie: Creating a JFace dialog
newbie: Creating a JFace dialog [message #76941] Fri, 14 January 2005 13:49 Go to next message
Hi all
I'm quite new to the visual editor.
I'm trying now to create a new property sheet editor. Since I'm not fond
of writing GUI code by hand (I hate it in fact), I tried creating the
editor using the VE, without success up to now.
I'm quite sure its because I'm missing some important part...
Anybody can supply a pointer?
thx
Eric.
Re: newbie: Creating a JFace dialog [message #77045 is a reply to message #76941] Fri, 14 January 2005 16:50 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What is the problem you are having?
Rich Kulp
Re: newbie: Creating a JFace dialog [message #77360 is a reply to message #76941] Mon, 17 January 2005 10:13 Go to previous messageGo to next message
Eric Giguère wrote:
> Hi all
> I'm quite new to the visual editor. I'm trying now to create a new
> property sheet editor. Since I'm not fond of writing GUI code by hand (I
> hate it in fact), I tried creating the editor using the VE, without
> success up to now.
I suggest using VE to create a new SWT control that subclasses
Composite. Then your property sheet editor only needs to instantiate
your new control and use it. You eliminate 95%+ of manual coding that way.
Dave Orme
Visual Editor Project leader
db4objects Senior Engineer (www.db4o.com)
Essential Data Project maintainer (essentialdata.sf.net)
Re: newbie: Creating a JFace dialog [message #77752 is a reply to message #77360] Wed, 19 January 2005 23:17 Go to previous messageGo to next message
Hi David
I've done this, I've created a new Composite using the Visual Editor.
Now, How can I connect this composite to a dialog that will be the editor
that will be launched from the property sheet?
My composite class cannot be used as it is can't it? I'm missing the part
where I can link what I create using the VE with the dialog object.
thx for the help!
Eric.
David Orme wrote:
> Eric Giguère wrote:
>> Hi all
>> success up to now.
> Dave Orme
Re: newbie: Creating a JFace dialog [message #77919 is a reply to message #77752] Mon, 24 January 2005 08:48 Go to previous messageGo to next message
Eric Giguère wrote:
> Hi David
> part where I can link what I create using the VE with the dialog object.
Your dialog object has a createControl() method for creating its UI.
Just put one line in there:
public void createControl(Composite parent) {
new MyComposite(parent, SWT.NULL);
(of course, substitute your composite class for MyComposite...)
Dave Orme
Re: newbie: Creating a JFace dialog [message #78157 is a reply to message #77919] Tue, 25 January 2005 01:12 Go to previous messageGo to next message
Hi again.
I tried just that.
Also tried using the constants:
SWT.NONE and SWT.EMBEDDED, no use. I only get an empty dialog with ok and
cancel buttons in it.
Playing with composites like this is exactly what I am looking for. What
am I doing wrong..?
I created a composite using VE with a 2 labels and a text area. This is to
be used as a propertySheet editor. So, i have derived a class from
jface.dialogs.Dialog. In this class, i have the method:
I can't find the void method but ther is this one:
protected Control createDialogArea(Composite parent)
MyTestComposite comp = new MyTestComposite(parent,SWT.NULL);
return comp;
I can also see the createContents method but the doc discourages using it.
Anyway, no matter which I use, I always get my empty dialog.
I open the dialog from the PropertyDescriptor using this code:
result = new ExtendedDialogCellEditor(composite, getLabelProvider())
protected Object openDialogBox(Control cellEditorWindow)
TestDialog2 dialog = new TestDialog2(cellEditorWindow.getShell());
dialog.open();
return "whatever";
Sorry for the bother, but many thx for the help.
Eric.
David Orme wrote:
> Eric Giguère wrote:
>> Hi David
> Dave Orme
Re: newbie: Creating a JFace dialog [message #79143 is a reply to message #78157] Fri, 04 February 2005 15:22 Go to previous messageGo to next message
Eric Giguère wrote:
> Hi again.
> I tried just that.
> and cancel buttons in it.
> am I doing wrong..?
> to be used as a propertySheet editor. So, i have derived a class from
> return comp;
> dialog.open();
> return "whatever";
I'm sorry it's taken so long to get back to you. I've had one thing
after another come up, the last being a reinstall of my whole
computer... :-}
I think you're missing a layout manager on the parent. Try inserting:
parent.setLayout(new FillLayout());
before the line that creates your test Composite. Please write back if
this doesn't work.
Dave Orme
Re: newbie: Creating a JFace dialog [message #79156 is a reply to message #78157] Fri, 04 February 2005 15:59 Go to previous messageGo to next message
> return comp;
This code works fine for me:
public class TestDialog extends Dialog {
* @param parentShell
public TestDialog(Shell parentShell) {
super(parentShell);
/* (non-Javadoc)
* @see
org.eclipse.jface.dialogs.Dialog#createDialogArea(org.eclips e.swt.widgets.Composite)
protected Control createDialogArea(Composite parent) {
return new MyDialogContents(parent, SWT.NULL);
Best Regards,
Dave Orme
Re: newbie: Creating a JFace dialog [message #79230 is a reply to message #79156] Sun, 06 February 2005 22:00 Go to previous message
thx a lot David!
Eric
>> return comp;
> super(parentShell);
> /* (non-Javadoc)
> * @see
> Best Regards,
> Dave Orme
Re: newbie: Creating a JFace dialog [message #604484 is a reply to message #76941] Fri, 14 January 2005 16:50 Go to previous message
Rich Kulp
Re: newbie: Creating a JFace dialog [message #604600 is a reply to message #76941] Mon, 17 January 2005 10:13 Go to previous message
Eric Giguère wrote:
> Hi all
> success up to now.
Dave Orme
Re: newbie: Creating a JFace dialog [message #604727 is a reply to message #77360] Wed, 19 January 2005 23:17 Go to previous message
Hi David
thx for the help!
Eric.
David Orme wrote:
> Eric Giguère wrote:
>> Hi all
>> success up to now.
> Dave Orme
Re: newbie: Creating a JFace dialog [message #604768 is a reply to message #77752] Mon, 24 January 2005 08:48 Go to previous message
Eric Giguère wrote:
> Hi David
Dave Orme
Re: newbie: Creating a JFace dialog [message #604808 is a reply to message #77919] Tue, 25 January 2005 01:12 Go to previous message
Hi again.
I tried just that.
am I doing wrong..?
return comp;
dialog.open();
return "whatever";
Eric.
David Orme wrote:
> Eric Giguère wrote:
>> Hi David
> Dave Orme
Re: newbie: Creating a JFace dialog [message #604996 is a reply to message #78157] Fri, 04 February 2005 15:22 Go to previous message
Eric Giguère wrote:
> Hi again.
> I tried just that.
> am I doing wrong..?
> return comp;
> dialog.open();
> return "whatever";
computer... :-}
this doesn't work.
Dave Orme
Re: newbie: Creating a JFace dialog [message #605000 is a reply to message #78157] Fri, 04 February 2005 15:59 Go to previous message
> return comp;
super(parentShell);
/* (non-Javadoc)
* @see
Best Regards,
Dave Orme
Re: newbie: Creating a JFace dialog [message #605020 is a reply to message #79156] Sun, 06 February 2005 22:00 Go to previous message
thx a lot David!
Eric
>> return comp;
> super(parentShell);
> /* (non-Javadoc)
> * @see
> Best Regards,
> Dave Orme
Previous Topic:VE-inspired XML plugin?
Next Topic:[JEM] newbie questions
Current Time: Sun Aug 31 22:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.05679 seconds
