Home » Modeling » GMF (Graphical Modeling Framework) » enforce fixed node size on node creation
enforce fixed node size on node creation [message #76903] Sat, 11 November 2006 11:38 Go to next message
Originally posted by: mail.volker-wegert.de
Hi all,
I've managed to make some "elements" (I'm still not sure what would be the
right term - is it "nodes"?) non-resizable by adding Minimum Size / Maximum
Size / Size settings to the Figure and setting the Node Resize Constraint to
"none". The default size is used when creating new elementy by clicking with
the proper tool enabled - fine. Now it's still possible to draw elements of a
different size by clicking and dragging a different size. How can I inhibit
this?
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
* "Drei Uhr morgens ist immer zu früh und immer zu spät für das, was du
* vorhast." (Jean-Paul Sartre)
Re: enforce fixed node size on node creation [message #77815 is a reply to message #76903] Wed, 15 November 2006 09:35 Go to previous message
Originally posted by: 5d5.mail.ru
This issue is still unresolved
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114061
Volker Wegert wrote:
> Hi all,
> this?
> Thanks
> Volker
Previous Topic:label showing as <...>
Next Topic:Setting a property that should not change afterwards
Current Time: Thu Nov 13 23:57:53 EST 2025
Powered by FUDForum. Page generated in 0.10041 seconds
