Home » Language IDEs » PHP Development Tools (PDT) » Can't Create Debug Launch Configuration
Can't Create Debug Launch Configuration [message #76852] Wed, 23 July 2008 18:50 Go to next message
Hi. I'm trying to install the "all in one" 3.3.2 Eclipse/PDT with XDebug.
I've got it working so that I can see that XDebug is loaded (for example,
in phpinfo()), but when I try to create a new Debug Launch Configuration,
and click on "New_Configuration" under "PHP Web Script with XDebug", I get
the following error: "An error has occurred. See error log for more
details.
org.eclipse.php.internal.core.util.FileUtils.fileExists(Ljav a/lang/String;)Z ".
Here is the first part of the eclipse error log:
!SESSION 2008-07-23 14:44:25.734
eclipse.buildId=M20080221-1800
java.version=1.6.0_05
Command-line arguments: -os win32 -ws win32 -arch x86 -consolelog
!ENTRY org.eclipse.osgi 2 1 2008-07-23 14:46:04.000
!MESSAGE NLS missing message: DebugConnectionThread_oldDebuggerVersion in:
org.e
clipse.php.internal.debug.core.PHPDebugCoreMessages
!ENTRY org.eclipse.osgi 2 1 2008-07-23 14:46:04.015
!MESSAGE NLS missing message: DebugServerTestEvent_success in:
org.eclipse.php.i
!MESSAGE NLS missing message: DebugServerTestEvent_timeOutMessage in:
org.eclips
!ENTRY org.eclipse.jface 4 2 2008-07-23 14:47:15.406
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".[/quote]
I don't really understand this, but it looks like I might be using an "old
Debugger Version".
At this point, I am unable to create a Debug Launch Configuration (the OK
button is grayed out). So I'm stuck.
Should I be using a different Eclipse version other than 3.3.2? A newer
version of XDebug? (I'm using "php_xdebug-2.0.0-5.2.2.dll").
Thanks for any help you can give me. Mark
Re: Can't Create Debug Launch Configuration [message #76902 is a reply to message #76852] Thu, 24 July 2008 04:27 Go to previous messageGo to next message
PDT 1.0.3 has Xdebug support built in. It looks like you have tried to install the old plugins that
were a bolt on to PDT before xdebug got integrated into it. You need to remove them.
Also I recommend moving to xdebug version 2.0.3 as there will be useful bug fixes in it.
Dave Kelsey
> XDebug. I've got it working so that I can see that XDebug is loaded (for
> example, in phpinfo()), but when I try to create a new Debug Launch
> Configuration, and click on "New_Configuration" under "PHP Web Script
> with XDebug", I get the following error: "An error has occurred. See
> error log for more details.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> in: org.e
> org.eclipse.php.i
> org.eclips
> "old Debugger Version".
> OK button is grayed out). So I'm stuck.
Re: Can't Create Debug Launch Configuration [message #77063 is a reply to message #76902] Thu, 24 July 2008 14:22 Go to previous messageGo to next message
Thanks very much. I've got it working now. When you recommend xdebug
version 2.0.3, is the the DLL (I'm on Windows) you are referring to. Do
you happen to know where I can download this compiled for Windows? Thanks
again. Mark
Re: Can't Create Debug Launch Configuration [message #77085 is a reply to message #77063] Thu, 24 July 2008 15:51 Go to previous messageGo to next message
All things relating to the xdebug php extension can be found at http://www.xdebug.org.
You can download the binary from there.
Dave Kelsey
> Thanks again. Mark
Re: Can't Create Debug Launch Configuration [message #77095 is a reply to message #77085] Thu, 24 July 2008 18:31 Go to previous message
Thanks very much. I had looked around for the DLL but only had seen
source. I'm up and running. Mark
Previous Topic:Setting mark in the code
Next Topic:[Dltk-dev] script parse/syntax errors not markers anymore on thefile? (and shown in problems view)
Current Time: Thu Nov 20 11:57:36 EST 2025
Powered by FUDForum. Page generated in 0.06822 seconds
