Home » Archived » XML Schema Definition (XSD) » UML diagram in the JavaDoc of the XSD project
UML diagram in the JavaDoc of the XSD project [message #6901] Sun, 24 November 2002 18:35 Go to next message
The UML diagrams I found here
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javado
c/org/eclipse/xsd/package-summary.html#details for the XSD project, is that
auto-generated by some tool from the code directly (if yes, which tool) or
it is drawn by developer manually?
Thank you.
Re: UML diagram in the JavaDoc of the XSD project [message #6926 is a reply to message #6901] Mon, 25 November 2002 06:32 Go to previous message
Hal,
The diagrams were hand drawn using Rational Rose 98 and the code was generated
from the diagrams. The EMF technology used to develop XSD allows this process
to be reversed as well, i.e., you can annotate your Java so that a .ecore
(simplified UML) model can be extracted from it and then free vendor tools like
Omondo can be used to render a UML class diagram. Check out the EMF forum for
details...
> Thank you.
Re: UML diagram in the JavaDoc of the XSD project [message #563940 is a reply to message #6901] Mon, 25 November 2002 06:32 Go to previous message
Hal,
details...
> Thank you.
Previous Topic:UML diagram in the JavaDoc of the XSD project
Next Topic:Loading schemas from WSDL documents
Current Time: Wed Oct 29 14:57:56 EDT 2025
Powered by FUDForum. Page generated in 0.03482 seconds
