Home » Archived » Visual Editor (VE) » VE and Custom-Widgets
VE and Custom-Widgets [message #76815] Fri, 14 January 2005 10:56 Go to next message
Is it possible to use custom widgets in VE. The problem I'm facing is
that SWT-Widget should not be subclassed and that's why I'm going to
layout my classes in the following manner:
--------------------8<--------------------
Object
+ AbstractSwtWidget
+ SingleValueField (uses an org.eclipse.swt.Text)
+ TextField
+ NumberField
+ DateField
+ FormattedField
+ MultiValueField
+ DropDown (uses an org.eclipse.swt.Combo)
+ ListBox (uses an org.eclipse.swt.List )
All of these fields have at least these constructors:
* TextField() // not really useful but without its not a been
* TextField(Composite parent, int style) // same than all SWT-Widgets
Can I use something like that in VE out of the box (I assume not)?
What has to done to use something like that in VE?
Can there be done at all?
Does this also suffer from the problem but there is a solution to this
problem? I think this is the preferred way in SWT to create your own
widget if I have understood the docs appropiately.
Object
+ DateField (uses an org.eclipse.swt.Text)
+ NumberField (uses an org.eclipse.swt.Text)
Are there any known problem regarding eclipse-3.1M4 and VE because on
eclipse 3.0.1 everything is working as expected but eclipse 3.1M4 I get
a ClassCastException
Tom
Re: VE and Custom-Widgets [message #76832 is a reply to message #76815] Fri, 14 January 2005 11:19 Go to previous messageGo to next message
Tom Schindl wrote:
> Object
> + AbstractSwtWidget
> + TextField
> + NumberField
> + DateField
> + FormattedField
> + MultiValueField
Rich or somebody please correct me if I'm wrong, but I don't believe
this will work in VE because it does not inherit from anywhere in the
SWT class hierarchy.
The way SWT itself does this sort of thing is to subclass either Canvas
or Composite and draw or embed the other control inside. See CLabel,
CCombo, etc. (the classes that begin with an extra 'C'.
If you subclass Composite, you can even use VE to design your new
control. :-)
Once you have your custom control written, you can use the "Choose Bean"
button on the tool bar to place it on your form.
Or read any of several recent threads about how to add your control to
the palette.
Dave Orme
Visual Editor Project leader
db4objects Senior Engineer (www.db4o.com)
Essential Data Project maintainer (essentialdata.sf.net)
Re: VE and Custom-Widgets [message #76864 is a reply to message #76832] Fri, 14 January 2005 11:39 Go to previous messageGo to next message
> control. :-)
So this would work?
Object
+ AbstractSwtWidget (extends org.eclipse.swt.Composite)
+ TextField
+ NumberField
+ DateField
+ FormattedField
+ MultiValueField
> the palette.
> Dave Orme
Re: VE and Custom-Widgets [message #76911 is a reply to message #76864] Fri, 14 January 2005 13:43 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
As long as your constructor is
xyz(Composite parent, int style)
Then we should be able to handle it.
Tom Schindl wrote:
>> Canvas or Composite and draw or embed the other control inside. See
>> CLabel, CCombo, etc. (the classes that begin with an extra 'C'.
>> control. :-)
>> Bean" button on the tool bar to place it on your form.
> So this would work?
> Object
> + TextField
> + NumberField
> + DateField
> + FormattedField
> + MultiValueField
>> the palette.
>> Regards,
>> Dave Orme
Rich Kulp
Re: VE and Custom-Widgets [message #77101 is a reply to message #76911] Sun, 16 January 2005 08:06 Go to previous messageGo to next message
Originally posted by: tomAtLinux.gmx.at
Hi Rich,
do you mean that I could use the structure without deriving my
widget from a composite?
Tom
>>> control. :-)
>> So this would work?
>> Object
>> + TextField
>> + NumberField
>> + DateField
>> + FormattedField
>> + MultiValueField
>>> to the palette.
>>> Regards,
>>> Dave Orme
Re: VE and Custom-Widgets [message #77143 is a reply to message #77101] Sun, 16 January 2005 16:12 Go to previous messageGo to next message
No, I meant in addition. You need the right constructor and you need to
inherit from Composite or Canvas.
Rich Kulp
Re: VE and Custom-Widgets [message #77331 is a reply to message #77143] Mon, 17 January 2005 09:30 Go to previous messageGo to next message
Ok. I have now rethought my Object-Structure and use a MVC. One more
question what when it comes to table-controls. Can I also have a:
TextColumn (extends TableColumn) and use it in the VE?
Tom
Re: VE and Custom-Widgets [message #77345 is a reply to message #77331] Mon, 17 January 2005 09:54 Go to previous message
That's a good question. We've never tested it, so I don't know. Give it
a try, but make sure you have a constructor of
public TextColumn (Table parent, int style)
> Tom
>> to inherit from Composite or Canvas.
Rich Kulp
Re: VE and Custom-Widgets [message #604431 is a reply to message #76815] Fri, 14 January 2005 11:19 Go to previous message
Tom Schindl wrote:
> Object
> + AbstractSwtWidget
> + TextField
> + NumberField
> + DateField
> + FormattedField
> + MultiValueField
control. :-)
the palette.
Dave Orme
Re: VE and Custom-Widgets [message #604441 is a reply to message #76832] Fri, 14 January 2005 11:39 Go to previous message
> control. :-)
So this would work?
Object
+ TextField
+ NumberField
+ DateField
+ FormattedField
+ MultiValueField
> the palette.
> Dave Orme
Re: VE and Custom-Widgets [message #604454 is a reply to message #76864] Fri, 14 January 2005 13:43 Go to previous message
>> control. :-)
> So this would work?
> Object
> + TextField
> + NumberField
> + DateField
> + FormattedField
> + MultiValueField
>> the palette.
>> Regards,
>> Dave Orme
Rich Kulp
Re: VE and Custom-Widgets [message #604528 is a reply to message #76911] Sun, 16 January 2005 08:06 Go to previous message
Hi Rich,
Tom
>>> control. :-)
>> So this would work?
>> Object
>> + TextField
>> + NumberField
>> + DateField
>> + FormattedField
>> + MultiValueField
>>> to the palette.
>>> Regards,
>>> Dave Orme
Re: VE and Custom-Widgets [message #604542 is a reply to message #77101] Sun, 16 January 2005 16:12 Go to previous message
Rich Kulp
Re: VE and Custom-Widgets [message #604589 is a reply to message #77143] Mon, 17 January 2005 09:30 Go to previous message
Tom
Re: VE and Custom-Widgets [message #604595 is a reply to message #77331] Mon, 17 January 2005 09:54 Go to previous message
> Tom
Rich Kulp
Previous Topic:Using customised wrapper beans in VE
Next Topic:Import JBuilder GUI Projects to Eclipse VE
Current Time: Sat Nov 15 09:35:32 EST 2025
Powered by FUDForum. Page generated in 0.06326 seconds
