Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] HibernateResource with mapping file
[Teneo] HibernateResource with mapping file [message #76804] Tue, 27 March 2007 15:18 Go to next message
I am using the HibernateResource to get my Teneo resource, but now I want
to use a static hibernate mapping XML file. How do I specifiy that the
mapping file should be used, or any other persistence options, when using
a resource.?
I have tried specifying the option in the load() method call with no
success.
Mark.
Re: [Teneo] HibernateResource with mapping file [message #76820 is a reply to message #76804] Tue, 27 March 2007 15:54 Go to previous messageGo to next message
Hi Mark,
The persistenceoptions are relevant only for the initialization of the HbDataStore. One of the
persistenceoptions is: PersistenceOptions.USE_MAPPING_FILE. If you set this true when initializing a
datastore then it should use a static hibernate mapping file (it searches in the classpath of the
generated java classes).
The few extra options relevant for a hibernateresource are mentioned on this page:
http://www.elver.org/hibernate/hibernateresources.html
gr. Martin
> want to use a static hibernate mapping XML file. How do I specifiy that
> the mapping file should be used, or any other persistence options, when
> using a resource.?
> success.
> Mark.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] HibernateResource with mapping file [message #76837 is a reply to message #76820] Tue, 27 March 2007 15:57 Go to previous messageGo to next message
Martin,
So I must use a datastore then.??
Currently I am not creating a datastore explicitly.
Mark.
Re: [Teneo] HibernateResource with mapping file [message #76851 is a reply to message #76837] Tue, 27 March 2007 16:07 Go to previous messageGo to next message
Mark,
I think you mentioned that you use a ehb file. In the version of Teneo from beginning of March you
can also specify all persistenceoptions in the ehb file.
gr. Martin
Mark wrote:
> Martin,
> Mark.
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #76867 is a reply to message #76851] Tue, 27 March 2007 16:56 Go to previous messageGo to next message
Martin,
By the time I saw your reply I had converted to use a datastore...
Now, when I specify the mapping file I can not access or load any objects.
If I don't specify the mapping file everything works.
I get an error for the initial query that says "Object" not mapped...
1535 [main] DEBUG org.hibernate.jdbc.JDBCContext - after transaction begin
1535 [main] DEBUG
org.eclipse.emf.teneo.hibernate.resource.HibernateResource - Loading
resource hibernate://?dsname=SrdV4&query1=FROM Echostar using defined
queries
1539 [main] DEBUG org.hibernate.engine.query.QueryPlanCache - unable to
locate HQL query plan in cache; generating (FROM Echostar)
1599 [main] DEBUG org.hibernate.hql.ast.QueryTranslatorImpl - parse() -
HQL: FROM Echostar
1608 [main] DEBUG org.hibernate.hql.ast.AST - --- HQL AST ---
\-[QUERY] 'query'
\-[SELECT_FROM] 'SELECT_FROM'
\-[FROM] 'FROM'
\-[RANGE] 'RANGE'
\-[IDENT] 'Echostar'
1608 [main] DEBUG org.hibernate.hql.ast.ErrorCounter -
throwQueryException() : no errors
1653 [main] DEBUG org.hibernate.hql.antlr.HqlSqlBaseWalker - select <<
begin [level=1, statement=select]
1698 [main] ERROR org.eclipse.emf.teneo.hibernate.HbMapperException -
Exception when saving resource SrdV4
org.hibernate.hql.ast.QuerySyntaxException: Echostar is not mapped [FROM
Echostar]
org.hibernate.hql.ast.util.SessionFactoryHelper.requireClass Persister(SessionFactoryHelper.java:158)
org.hibernate.hql.ast.tree.FromElementFactory.addFromElement (FromElementFactory.java:87)
org.hibernate.hql.ast.tree.FromClause.addFromElement(FromCla use.java:70)
Mark.
Re: [Teneo] HibernateResource with mapping file [message #76884 is a reply to message #76867] Tue, 27 March 2007 17:04 Go to previous messageGo to next message
Mark,
It seems that it can't find the hbm mapping file. When you turn on logging then when initializing a
datastore you should the following line:
Searching hbm files in class paths of epackages
and then the list of paths it looks for the hbm file.
Can you check if the hbm file is actually there in the output folder in one of these paths (with me
such files don't always get copied to the output folder without first explicitly setting it in the
build.properties)?
The file should be called hibernate.hbm.xml.
gr. Martin
Mark wrote:
> Martin,
> objects. If I don't specify the mapping file everything works.
> 1535 [main] DEBUG
> queries
> HQL: FROM Echostar
> \-[QUERY] 'query'
> \-[FROM] 'FROM'
> \-[RANGE] 'RANGE'
> Echostar]
> at
> at
> at
> Mark.
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #76901 is a reply to message #76884] Tue, 27 March 2007 17:21 Go to previous messageGo to next message
Martin,
I did have a problem generating the mapping file with manually, so I just
called getMappingXML() after the store is initialized.
Yes it seems as though it is found...
567 [main] INFO org.hibernate.cfg.Environment - using JDK 1.4
java.sql.Timestamp handling
626 [main] DEBUG org.eclipse.emf.teneo.ERuntime - Determining concrete
classes for package srd
742 [main] DEBUG org.eclipse.emf.teneo.hibernate.HbSessionDataStore -
745 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - >>>> Building or
descriptor file List
747 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
:hibernate.hbm.xml
751 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
/srd/hibernate.hbm.xml
773 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
/hibernate.hbm.xml
780 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
/srd/impl/hibernate.hbm.xml
780 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - !!Found!!
781 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
/org/eclipse/emf/ecore/impl/hibernate.hbm.xml
784 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
/org/eclipse/emf/ecore/hibernate.hbm.xml
789 [main] DEBUG org.eclipse.emf.teneo.util.StoreUtil - Try path:
/org/eclipse/emf/hibernate.hbm.xml
7
Re: [Teneo] HibernateResource with mapping file [message #76917 is a reply to message #76901] Tue, 27 March 2007 17:26 Go to previous messageGo to next message
and echostar is mapped in the hbm file?
You can also turn on debugging for hibernate to get some more info:
log4j.logger.org.hibernate=debug
Also if you debug into the hbdatastore then you should see that it passes the hbm to the hibernate
configuration. Does it do that?
gr. Martin
Mark wrote:
> Martin,
> just called getMappingXML() after the store is initialized.
> or descriptor file List
> :hibernate.hbm.xml
> /hibernate.hbm.xml
> 7
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #76976 is a reply to message #76917] Tue, 27 March 2007 17:55 Go to previous message
Martin,
Solved. The mapping file being used was empty, from my attempt at manual
creation.
Mark.
Re: [Teneo] HibernateResource with mapping file [message #603888 is a reply to message #76804] Tue, 27 March 2007 15:54 Go to previous message
Hi Mark,
gr. Martin
> using a resource.?
> success.
> Mark.
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #603892 is a reply to message #76820] Tue, 27 March 2007 15:57 Go to previous message
Martin,
Mark.
Re: [Teneo] HibernateResource with mapping file [message #603894 is a reply to message #76837] Tue, 27 March 2007 16:07 Go to previous message
Mark,
gr. Martin
Mark wrote:
> Martin,
> Mark.
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #603897 is a reply to message #76851] Tue, 27 March 2007 16:56 Go to previous message
Martin,
1535 [main] DEBUG
queries
HQL: FROM Echostar
\-[QUERY] 'query'
\-[FROM] 'FROM'
\-[RANGE] 'RANGE'
Echostar]
Mark.
Re: [Teneo] HibernateResource with mapping file [message #603898 is a reply to message #76867] Tue, 27 March 2007 17:04 Go to previous message
Mark,
build.properties)?
gr. Martin
Mark wrote:
> Martin,
> 1535 [main] DEBUG
> queries
> HQL: FROM Echostar
> \-[QUERY] 'query'
> \-[FROM] 'FROM'
> \-[RANGE] 'RANGE'
> Echostar]
> at
> at
> at
> Mark.
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #603901 is a reply to message #76884] Tue, 27 March 2007 17:21 Go to previous message
Martin,
:hibernate.hbm.xml
/hibernate.hbm.xml
7
Re: [Teneo] HibernateResource with mapping file [message #603903 is a reply to message #76901] Tue, 27 March 2007 17:26 Go to previous message
gr. Martin
Mark wrote:
> Martin,
> :hibernate.hbm.xml
> /hibernate.hbm.xml
> 7
The Netherlands
Re: [Teneo] HibernateResource with mapping file [message #603916 is a reply to message #76917] Tue, 27 March 2007 17:55 Go to previous message
Martin,
creation.
Mark.
Previous Topic:[Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING
Next Topic:Remove whitespaces from generation
Current Time: Sun Aug 31 01:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.05927 seconds
