Home » Language IDEs » PHP Development Tools (PDT) » PDT 1.0.3 Xdebug Breakpoint Problem
PDT 1.0.3 Xdebug Breakpoint Problem [message #76802] Wed, 23 July 2008 03:13 Go to next message
I'm trying to use Xdebug for debugging, and the breakpoints wont trigger.
I setup an xdebug log and there is a discrepancy with the file paths set:
file:///D:/Documents%20and%20Settings/Ian/workspace/php5/htd ocs/index.php
file:///D:%5CDocuments%20and%20Settings%5CIan%5Cworkspace%5C php5%5Chtdocs%5Cindex.php
The forward slashes are url encoded when the breakpoints are set in the
log. Any way to fix this (assuming that's the problem)? Using
xdebug_break(); makes the debugging work.
Re: PDT 1.0.3 Xdebug Breakpoint Problem [message #76818 is a reply to message #76802] Wed, 23 July 2008 03:43 Go to previous messageGo to next message
XDebug expects the file to be URI encoded, so what you are showing there is correct and expected.
What lines have you tried to set breakpoints on ? when php compiles a script some lines are removed
so even though there is code on that line of the source code, php when it executes doesn't see that
line anymore.
I gather from your example that your apache htdocs points to your workspace. It should not be a
problem but you could try using a different location for your workspace/htdocs location and not use
the "Documents and Settings" directory but use one with no spaces to see if that is the cause as well.
Cheers
Dave Kelsey
> trigger. I setup an xdebug log and there is a discrepancy with the file
> paths set:
Re: PDT 1.0.3 Xdebug Breakpoint Problem [message #76834 is a reply to message #76818] Wed, 23 July 2008 04:49 Go to previous message
For some reason updating to xdebug 2.0.3 from 2.0.2 fixed the issue (I
also disabled eAccelerator so that might have fixed it too). Thanks for
the response though!
Previous Topic:Search (and Replace) on multiple files
Next Topic:submitting form results in file dialog window
Current Time: Sat Nov 08 19:24:34 EST 2025
Powered by FUDForum. Page generated in 0.04496 seconds
