Home » Eclipse Projects » Remote Application Platform (RAP) » error with RAP demo from CVS head
error with RAP demo from CVS head [message #76757] Wed, 05 March 2008 11:19 Go to next message
Hi all,
I've just updated my workspace with the current head from CVS.
The demo app is not running anymore.
I get the following message:
"Could not evaluate javascript response:
TypeError: org.eclipse.swt.theme.Dimensions has no properties"
I don't know if its only in my workspace or if it is a general problem.
Does somebody have a clue?
Thanks & Regards
Oliver
Re: error with RAP demo from CVS head [message #76773 is a reply to message #76757] Wed, 05 March 2008 11:30 Go to previous messageGo to next message
Me again,
I guess that its due to changes in RWT appearances.
Can somebody confirm this? Have there been recently changes in the qx appearances of RAP??
Thanks & Regards
Oliver
Poncho schrieb:
> Hi all,
> Thanks & Regards
> Oliver
Re: error with RAP demo from CVS head [message #76789 is a reply to message #76757] Wed, 05 March 2008 11:34 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Oliver,
That's right, the class org.eclipse.swt.theme.Dimensions has been replaced
by a more general one called ThemeStore. Do you have a custom widget that
refers to the Dimensions store? If so please change the appearance.js code
to use the new ThemeValues class. Here is an example for a custom
appearance that uses the new classes:
"mycontrol" :
style : function( states ) {
var tv = new org.eclipse.swt.theme.ThemeValues( states );
result = { };
result.spacing = tv.getDimension( "mycontrol.spacing" );
result.margin = tv.getBoxDimensions( "mycontrol.margin" );
return result;
The change was neccesary to introduce custom widget variants (think css
classes) that allow for a more flexible theming. Documentation will follow.
Sorry for the inconvenience.
Ralf
Re: error with RAP demo from CVS head [message #76946 is a reply to message #76789] Thu, 06 March 2008 02:39 Go to previous message
Hi Ralf,
yes that was the solution.
I've exchanged all entries of org.eclipse.swt.theme.Dimensions with
your stated example.
Thanks for the support. :-)
Oliver
Ralf Sternberg schrieb:
> Hi Oliver,
> "mycontrol" :
> result = { };
> return result;
> Best regards,
> Ralf
Previous Topic:Browser object and getUrl()
Next Topic:org.eclipse.rap.search project
Current Time: Fri Nov 21 04:06:07 EST 2025
Powered by FUDForum. Page generated in 0.06684 seconds
