| Exception when try to add path variables [message #76721] |
Mon, 21 July 2008 22:10 |
Hey!
I'm using Eclipse 3.4 and PDT 2.0 (2.0.0 Integration Build: I20080721)
when I try to add a path variable, I can, but nothing happend, the
variable doesn't appear, then when I click on the "Ok" button an error
message is set.
Exception message:
!ENTRY org.eclipse.ui 4 0 2008-07-20 12:45:53.375
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.php.internal.ui.preferences.includepath.Variable CreationDialog.nameConflict(Unknown
Source)
org.eclipse.php.internal.ui.preferences.includepath.Variable CreationDialog.nameUpdated(Unknown
Source)
org.eclipse.php.internal.ui.preferences.includepath.Variable CreationDialog.doFieldUpdated(Unknown
Source)
org.eclipse.php.internal.ui.preferences.includepath.Variable CreationDialog.access$0(Unknown
Source)
org.eclipse.php.internal.ui.preferences.includepath.Variable CreationDialog$NewVariableAdapter.dialogFieldChanged(Unknown
Source)
org.eclipse.php.internal.ui.wizards.fields.DialogField.dialo gFieldChanged(Unknown
Source)
org.eclipse.php.internal.ui.wizards.fields.StringDialogField .doModifyText(Unknown
Source)
org.eclipse.php.internal.ui.wizards.fields.StringDialogField $2.modifyText(Unknown
Source)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:167)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:2434)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:3923 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3790 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:227 3)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:187)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3877 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2078)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:23 70)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3420)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
FUDForum. Page generated in 7.15809 seconds
