| EMF model from XML Schema fails if duration has default value [message #76682] |
Sat, 27 December 2008 15:23  |
In standard ebRS rim.xsd (per enterprise healthcare integration,
www.ihe.net) we have a SubscriptionType defined with an optional duration
attribute:
<attribute name="notificationInterval" type="duration" use="optional"
default="P1D"/>
This gives NPE in XSDEcoreBuilder. But its okay if the default value
definition is removed.
Is this a known bug or an accepted limitation?
Dan Connelly, SOA Integration
S. Burlington, Vermont
| Re: EMF model from XML Schema fails if duration has default value [message #76729 is a reply to message #76714] |
Sun, 28 December 2008 12:42   |
--------------050806040905070605040205
Dan,
It worked fine for me, but then it occurred to me I ought to try a Sun
JRE. That resulted in this
at javax.xml.datatype.Duration.getYears(Duration.java:256)
com.sun.org.apache.xerces.internal.jaxp.datatype.DurationImp l.compare(DurationImpl.java:875)
at javax.xml.datatype.Duration.equals(Duration.java:872)
org.eclipse.emf.ecore.xml.type.internal.XMLDuration.equals(X MLDuration.java:128)
Looking at Duration's getYear implementation:
public int getYears() {
return getField(DatatypeConstants.YEARS).intValue();
and then considering that getField is defined to return null
* Gets the value of a field.
* @return
* If the specified field is present, this method returns
* a non-null non-negative {@link Number} object that
* represents its value. *If it is not present, return null.*
* For YEARS, MONTHS, DAYS, HOURS, and MINUTES, this method
* returns a {@link java.math.BigInteger} object. For
SECONDS, this
* method returns a {@link java.math.BigDecimal}.
public abstract Number getField(final DatatypeConstants.Field
field);
it's not surprising that we'd get a null pointer exception in getYears.
It's really a bug in the JRE, but if you open a bugzilla, and I put in
workaround code (overrides of getYears and related methods) in our
XMLDuration implementation. So please open a bugzilla. Note that it's
an issue that needs to be fixed in the EMF core runtime, so best to open
the bugzilla there.
Dan Connelly wrote:
> Ed:
> Eclipse SDK, Version: 3.4.0
> Build id: I20080617-2000
> XML Schema Definition (XSD) - org.eclipse.xsd.ecore.converter Version:
> 2.4.0.v200808251517
> Build id: 200808251517
> Eclipse Modeling Framework (EMF) Version: 2.4.1.v200808251517
> Try:
> File->New->Project...->EMF Project->...->XML Schema (Importer)->
> Model URIs:
> ftp://ftp.ihe.net/TF_Implementation_Material/ITI/schema/ebRS /rim.xsd
> ->Load
> Fundamentally, this XSD should be same as
> <OASIS>/cvsroot/ebxmlrr/ebxmlrr-spec/misc/3.0/schema/rim.xsd
> However, I have used only the IHE URI given above.
> --Dan
<html>
<head>
http-equiv="Content-Type">
</head>
Dan,<br>
<br>
JRE.
| Re: EMF model from XML Schema fails if duration has default value [message #76761 is a reply to message #76745] |
Tue, 30 December 2008 12:05  |
Dan,
Intentionally bogus! :-P It would have been better to leave them
abstract if a conforming implementation of getField is going to result
in null pointer exceptions. Jeesh. The changes are committed for 2.4.2
and 2.5.0.
Dan Connelly wrote:
> Sun's JAXP concrete DurationImpl over-rides the getXXXX methods of the
> abstract parent Duration class for Sun jre 1.5 and Sun jre 1.6. Both
> classes list the same authors in both releases. From this I conclude
> that the NPE must be an intentional "feature" of Sun's recent
> releases! (?) All concrete classes of Duration need to provide these
> over-rides (it seems).
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=259794
| Re: EMF model from XML Schema fails if duration has default value [message #603574 is a reply to message #76682] |
Sat, 27 December 2008 15:58  |
Dan,
What would I need to do to reproduce this problem myself?
> duration attribute:
> default="P1D"/>
> value definition is removed.
| Re: EMF model from XML Schema fails if duration has default value [message #603579 is a reply to message #76714] |
Dan,
* @return
SECONDS, this
field);
the bugzilla there.
Dan Connelly wrote:
> Ed:
> 2.4.0.v200808251517
> Try:
> Model URIs:
> ->Load
> --Dan
<html>
<head>
</head>
Dan,<br>
<br>
JRE.
| Re: EMF model from XML Schema fails if duration has default value [message #603584 is a reply to message #76745] |
Dan,
and 2.5.0.
FUDForum. Page generated in 0.08471 seconds
