Home » Modeling » GMF (Graphical Modeling Framework) » Node Labels in GMF
Node Labels in GMF [message #76522] Fri, 10 November 2006 08:33 Go to next message
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
--------------030501050202000503050109
Content-Type: text/plain; charset=UTF-8; format=flowed
I´ve got a problem with my GMF editor. I´ve defined nodes and label
mappings for them. The attributes of the concerned eclasses that act as
labels have the type String. When I insert a node in the diagram I get
what you can see in bad.JPG. I can edit the attribute value manually.
But what I want can be seen in good.JPG. I want to insert the node and
the label should be shown as <...> or whatever I specify as standard.
The attribute value that acts as the label should remain an empty String
until I specifiy it in the properties view. When I specify the class
attribute in the properties view via a the drop down menu (this feature
I already got to work) it should be shown as the nodes label. This works
for a node (called operator) I defined but not for the others, even
though I seem to have set the same settings. Maybe I forgot something I
don´t remember having it specified. Is there a special setting for a
node that stops the input mask (as seen in bad.JPG) from showing up?
Greetings,
Christian
Content-Type: image/jpeg;
name="good.JPG"
Content-Disposition: inline;
filename="good.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CABYAGMDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iivMLjQ/FNz8abq4t/F bQaULUTf2elx
KWiV4GhVxGyGEnzUZsEnpkjmgD0+iuObRtaS9js2+IOpC4lRpEj+w2mSqkAn /Vf7Q/X0NT/8
I14i/wCh71T/AMAbP/41QB1VFea/8IZ44/4WR/a//CWy/wBheR5flfaH37/s 3l+Z5Gzyc+b8
+OnfHaug/wCEa8Rf9D3qn/gDZ/8AxqgDqqK5X/hGvEX/AEPeqf8AgDZ//Gq5 TxD4e8Wp4/8A
CcsXjOX7F5kcc0Ms0kLXjRySTSAxwp5X+qG3nGduD7gHqtFFFABRRRQAUUUU AFcnGJD8UtUE
TKsh0K12My7gD59xgkZGR7ZFdZXnUfi7R4/jlc6Hi+OpzWMVnjyU8kbFkuN2 /fu5WTGNvUde
aAK97Za3/wAJNHDNIZNcf57W7Q4jWMbv9ngDJBBB6988+jWa3KWkS3ksctwB 87xIUUn2BJ/n
+XSpTFGZVlKKZFUqrkcgHGQD6HA/IU6ojDlbLlLmOT0u8vpvECx6/cXdndh3 +yWMcWy0kGDg
iUFvOfb5nysyEqu8wIVDVuR63p0v2bZcZ+03ctlF8jfNNF5m9enGPJk5PB28 E5GdCirIOX1r
Vre4gt7jTNSvlv1lnht4bSAzee8b7JEkiYY8sSKqmQlNuRiVA+TR1CS+l1zw HJqcMcN415cG
WNDwD9km7ZIBxglQzAHIDOBuPbV514y8XaPpvxK8I6PeC+F8JxND5MKNG/nr JbqGYuCuCxY4
U8D34APRaKKKACiiigAooooAK5CGzsn+LN67afYmePSre4S4+yx+cJGeaNj5 m3fyiKuM4wK6
+uVt/wDkq+o/9gO1/wDR9xQB1VFFFABRRRQAVyHiazsn8a+EZZNPsZZ5ruSN pprWOSQKkEsq
BXZSy4dQw2kc/WuvrlfEv/I4eC/+v+4/9JJqAOqooooAKKKKACiiigArzq68 J+NpPinNr1t4
kWHQGRhFZPcTOqN9n2AmDhCBJ8+Nwz1yDXotFAHK/wBk+Nv+hs0v/wAEh/8A j9H9k+Nv+hs0
v/wSH/4/XVUUAea/8Ih49/4WR/bf/CUxf2R5Gz7N5s2zzfs3l7/s/wBzHm/P t3/jmug/snxt
/wBDZpf/AIJD/wDH66qigDlf7J8bf9DZpf8A4JD/APH65/WPCHj298Z6BqcP imIafZ+T9vhi
lmtVuNs7O2IV3KcxlV5bnHOBXpVFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAf//Z
name="bad.JPG"
filename="bad.JPG"
CABiAJUDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iiigAorzXR/F/j298Z6 /pk3haIafZ+d
9gmlimtVuNs6ouZm3Kcxlm4XnHGBXQf2t42/6FPS/wDwdn/4xQB1VFedeLvF Xj/RvDwvNP8A
CVrJfG7jiWGCWW/3RlJCzFURCuCqDPI+b6VrWet+NJ9NsZx4WsHea0hll83U Wt2WRo1Z1MZi
YrhiwwWJ4oA6+iuV/tbxt/0Kel/+Ds//ABisnwr4q8Yap8Q9b0jV9B+x6Ja+ f9jvfsc0fnbZ
VVPnYlWyhJ4HOMjigD0CiiigAooooAKKKKACiiigAooooAKKKKACiiigDlfD X/I4eNP+v+3/
APSSGuqrkPDN5ZP418XRR6hYyzzXcciww3UckgVIIonLIrFlw6lTuA5+tdfQ ByHjLVLoRnSR
ay29rdDZJfMfkIPVFxnBIyPmx3wO4n8O6/f3mm4uLGRzFsiS8LbY7glgueRn POTgEcHkdK3t
S0+DVdOnsbkExTLtJXqvcEe4OCPcUy4hjt7CCCFAkUckKIi9FUOoAFQovmvc tyXLaxJvvv8A
n3t/+/7f/EVlWmk31r4m1PWMW7fboLeHyvMYbPKMhznbznzPQYx3zW9RVkFb fff8+9v/AN/2
/wDiKN99/wA+9v8A9/2/+IqzRQBW333/AD72/wD3/b/4ijfff8+9v/3/AG/+ IqzRQBW333/P
vb/9/wBv/iKN99/z72//AH/b/wCIqzRQBW333/Pvb/8Af9v/AIio5rm8ggkm a2gKxqWIE5zg
DP8Acq7VbUf+QZd/9cX/APQTTAWwvrfU9Otr+zk8y1uokmhfaRuRgCpweRkE dasVz/gT/knn
hr/sFWv/AKKWugpAFFFFABRRRQB514N8I6PpvxK8XaxZm+F8JzDN50yNG/nr HcMVUICuCwUZ
Y8D349FrlfDX/I4eNP8Ar/t//SSGuqoAKhuYWnh2K4RgysCVyMqwPTI9Kmoo A5b7R49/6Bfh
r/wZT/8Axis+38QeNrnXL/SU0jw+LiyhhmkZtRm2kSl9uD5Oc/u2zwOo613N crpP/JS/E/8A
14af/O4oAX7R49/6Bfhr/wAGU/8A8Yo+0ePf+gX4a/8ABlP/APGK6migDlvt Hj3/AKBfhr/w
ZT//ABij7R49/wCgX4a/8GU//wAYrqaKAOW+0ePf+gX4a/8ABlP/APGKPtHj 3/oF+Gv/AAZT
/wDxiupooA5b7R49/wCgX4a/8GU//wAYqOZ/Hk8EkLaX4bCyKVJGpT5wRj/n hXW0UAZfhrTZ
tG8K6Rpdw0bT2VlDbyNGSVLIgUkZAOMj0FalFFABRRRQAUUUUAeVeHvEPi1P H/iyKXwZL9i8
ySSGaKGSFrxo5I4YyJJn8r/VDdxjO3I9+r/4SXxF/wBCJqn/AIHWf/x2uqoo A868XeMvGum+
HheaP4Luhffa44vJnVbvfGySFmC28hIwVQZPHzflrWfibxM+m2Mkvgu/nnlt IZZminghUSNG
rOoSSQOu1iVwwzxXX0UAcr/wkviL/oRNU/8AA6z/APjtc/4Q1jxLe/FXxJDq fhv7Fp/lvHDq
H2WdPtCwzFYRudihysjt8oGevQV6VRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQB/9k=
--------------030501050202000503050109--
Re: Node Labels in GMF [message #76668 is a reply to message #76522] Fri, 10 November 2006 10:07 Go to previous messageGo to next message
Christian,
Do you want the user to only be able to modify this label by choosing
one of the options in the drop down menu in the properties view? If so,
just set the Label Mapping's Read Only property to true. It will no
longer be editable on the diagram at all.
Cherie
Christian Dänekas wrote:
> Hello,
> Greetings,
> Christian
Re: Node Labels in GMF [message #76762 is a reply to message #76522] Fri, 10 November 2006 11:16 Go to previous messageGo to next message
Hi Christian
Your issue is that when you go into edit mode, the existing text <...> is
not being edited even though that is the text that shows on the diagram.
The string in your domain model is blank and by default the generated code
then displays <...>.
To fix this, create a default value for your String in your ecore model.
Note that the string default <...> is found on the LabelFigure in your
gmfmap file.
Cheers...
Anthony
"Christian D
Re: Node Labels in GMF [message #77031 is a reply to message #76668] Mon, 13 November 2006 05:28 Go to previous messageGo to next message
I already did that. This was the main reason I asked, because I
understood the functionality of "Read Only" in the Label mapping
properties the same waay you just told me. I forgot to mention that in
my initial post, sorry. The strage thing is that I get the right
behaviour for one node, but not for any of the other nodes in my diagram
although I set the Label Mapping to read only for all of them. When I
generate the gmfgen-model and generate the diagram code I sometimes get
the error that a "Resource is out of sync with the file system". Maybe
this has something to do with it? When I generate the code a second time
the error disappears. Maybe I try to start all over again, but this
can´t be the solution since I have to modify the generated code all over
again (constraints defined in java, definition of Propertydescriptors
etc.) and of course the model properties. Maybe you or someone else has
better solution. I´m using version 2.0M2 sice the callisto version
gave me some serious trouble defining the models the way I have to
(graphical and tooling models that is).
Greetings,
Christian
Cherie Revells schrieb:
> Christian,
> Cherie
Re: Node Labels in GMF [message #77148 is a reply to message #76668] Mon, 13 November 2006 09:50 Go to previous message
Ok, I still had an older version of my project and using it fixed my
problem. Some configuration management is a good idea while using GMF
;). Thanks for your help.
Greetings,
Christian
Previous Topic:Labeled Container - help
Next Topic:Copy/Paste
Current Time: Fri Nov 21 07:36:59 EST 2025
Powered by FUDForum. Page generated in 0.07593 seconds
