Home » Language IDEs » ServerTools (WTP) » Atributes prompting for custom tagilbs
Atributes prompting for custom tagilbs [message #76388] Thu, 24 February 2005 06:05 Go to next message
Originally posted by: borislav_sabev.yahoo.com
Hi all,
I need some help about taglibraries and tag attributes.
1. when i put taglib declaration in a jsp like this here:
<%@ taglib uri="/WEB-INF/taglibs/struts-logic.tld" prefix="logic" %>
the editor finds it and propmt me tags from this taglib. but I use
something like this <%@ taglib uri="struts-logic.tld" prefix="logic" %>
and specify the location of the taglib in web.xml, then the editor doesn't
prompt the tags. Is there some solution about this or at least is it
possible?
2. if the taglib is recognized by the jsp editor and propmts me the tags,
it doesn't prompt me the attributes of the tag. Is this implemented at all
or I have to tune the editor somehow? or may be the feature is not planned
at all?
I'll appreciate any help about these 2 issues.
Cheers
Borislav
Re: Atributes prompting for custom tagilbs [message #76513 is a reply to message #76388] Thu, 24 February 2005 11:29 Go to previous messageGo to next message
Borislav Sabev wrote:
> I need some help about taglibraries and tag attributes. 1. when i put
> doesn't prompt the tags. Is there some solution about this or at least
> is it possible?
To use the URI "struts-logic.tld", that string needs to be within a
taglib-uri element in the web.xml file. If that's the case and it's
not working, please open a bug.
> tags, it doesn't prompt me the attributes of the tag. Is this
> implemented at all or I have to tune the editor somehow? or may be the
> feature is not planned at all?
This should be working in M3. If not, please open a bug.
- Nitin
Re: Atributes prompting for custom tagilbs [message #76702 is a reply to message #76513] Fri, 25 February 2005 02:37 Go to previous messageGo to next message
That's right, it's in my web.xml file. Otherwise I'll not bother the
community here with obvious problems. This is snippet from my web.xml:
<jsp-config>
<taglib>
<taglib-uri>/struts-bean</taglib-uri>
<taglib-location>/WEB-INF/taglibs/struts-bean.tld</taglib-location >
</taglib>
<taglib>
<taglib-uri>/struts-html</taglib-uri>
<taglib-location>/WEB-INF/taglibs/struts-html.tld</taglib-location >
</taglib>
So as you suggested I'll open a bug.
I'm waiting the M3 - it's for today isn't it, so when I get M3 I'll check
the propmpting again and if it's still not working I'll open a new bug.
Thanks a lot for the fast answers!
Borislav
Re: Atributes prompting for custom tagilbs [message #76817 is a reply to message #76702] Fri, 25 February 2005 08:02 Go to previous message
Hi Borislav,
With:
in your web.xml, wouldn't you need:
<%@ taglib uri="/struts-html" prefix="logic" %>
instead of:
that you mentioned in your first mail? The uri's need to match.
Alternatively, you can use the uri specified in the tld and not bother
with the web.xml entries at all, i.e.:
<%@ taglib uri="http://jakarta.apache.org/struts/tags-logic"
prefix="logic" %>
HTH
Larry
> <jsp-config>
> <taglib>
> </taglib>
> <taglib>
> </taglib>
> check the propmpting again and if it's still not working I'll open a new
> bug.
> Borislav
Previous Topic:How to configure http.proxyHost with JST and Jboss 3.2.3 as generic server?
Next Topic:Disable automatic structured builder ?
Current Time: Thu Nov 06 15:22:40 EST 2025
Powered by FUDForum. Page generated in 0.03572 seconds
