Home » Archived » XML Schema Definition (XSD) » TODO: The default literal value "EnumMemberA" is invalid
TODO: The default literal value "EnumMemberA" is invalid [message #76307] Thu, 13 November 2008 11:52 Go to next message
I am having a problem with an attribute that is defined as fixed with a
simple type enumeration member:
<xs:attribute name="attr1" type="SimpleTypeA" fixed="EnumMemberA"/>
is generating:
protected static final Object ATTR1_EDEFAULT; // TODO The default value
literal "EnumMemberA" is not valid.
protected Object attr1 = ATTR1_EDEFAULT;
The causes a compilation error for unassigned static final field. I
believe that in the past (perhaps version EMF 2.2) it would have generated
this:
protected static final Object ATTR1_EDEFAULT =
ExampleFactory.eINSTANCE.createFromString(ExamplePackage.eIN STANCE.getSimpleTypeA(),
"EnumMemberA");
The full schema that was used for this example is:
<?xml version="1.0"?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://example.org"
xmlns="http://example.org">
<xs:simpleType name="SimpleBaseType">
<xs:restriction base="xs:token">
<xs:pattern value="[^\s]+"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="SimpleTypeA">
<xs:union memberTypes="SimpleTypeB SimpleTypeC"/>
</xs:simpleType>
<xs:simpleType name="SimpleTypeB">
<xs:restriction base="SimpleBaseType"/>
</xs:simpleType>
<xs:simpleType name="SimpleTypeC">
<xs:restriction base="SimpleBaseType">
<xs:enumeration value="EnumMemberA"/>
<xs:enumeration value="EnumMemberB"/>
<xs:enumeration value="EnumMemberC"/>
</xs:restriction>
</xs:simpleType>
<xs:complexType name="ComplexTypeA">
<xs:sequence>
<xs:element name="element1" type="xs:string"/>
<xs:element name="element2" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
I am running Eclipse Ganymede 3.4.1 with EMF 2.4.1 on Windows XP SP3.
John
Re: TODO: The default literal value "EnumMemberA" is invalid [message #76341 is a reply to message #76307] Thu, 13 November 2008 12:59 Go to previous message
John,
I see, because it's a union without a common base type. Please open a
bugzilla with this example and I'll look into fixing it.
> a simple type enumeration member:
> is generating:
> value literal "EnumMemberA" is not valid.
> generated this:
> "EnumMemberA");
> </xs:restriction>
> </xs:simpleType>
> </xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> John
Re: TODO: The default literal value "EnumMemberA" is invalid [message #603475 is a reply to message #76307] Thu, 13 November 2008 12:59 Go to previous message
John,
> is generating:
> generated this:
> "EnumMemberA");
> </xs:restriction>
> </xs:simpleType>
> </xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> John
Previous Topic:Generated EObjectValidator class
Next Topic:Generated EObjectValidator class
Current Time: Tue Dec 02 20:27:28 EST 2025
Powered by FUDForum. Page generated in 0.04259 seconds
