Home » Archived » M2M (model-to-model transformation) » [ATL] AADL Model Transformation
[ATL] AADL Model Transformation [message #76289] Wed, 12 March 2008 06:32 Go to next message
I'm new to ATL and trying to transfor AADL model to SIGNAL model.
I have an AADL metamodel with seven .ecore files, and try a very simple
transfor rule for systemType and systemImpl.
Here is the code I use:
module test; -- Module Template
create OUT : sme from IN : core;
rule RsysImpl{
from
s : core!SystemImpl
to
t : sme!ModelDeclaration(
name <- 'IMPL_' + s.name
rule RsysType{
from
s : core!SystemType
to
name <- 'TYPE_' + s.name
When the sample model includes only systemType instance, it works; but
when systemImpl instance is added, following exception occurs:
severe:The feature 'ystemType' is not a valid reference
java.lang.IllegalArgumentException: The feature 'ystemType' is not a
valid reference
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eReference(Basic EObjectImpl.java:742)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eObjectForURIFra gmentSegment(BasicEObjectImpl.java:511)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:758)
edu.cmu.sei.aadl.model.core.util.CoreResourceImpl.getEObject (CoreResourceImpl.java:374)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:734)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1077)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1168)
org.eclipse.emf.ecore.xmi.impl.SAXWrapper.endDocument(SAXWra pper.java:79)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.endEntity(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.end Entity(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.loa d(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.ski pSpaces(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$TrailingMiscDispatcher.dispatch(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
edu.cmu.sei.aadl.model.core.util.CoreResourceImpl.load(CoreR esourceImpl.java:276)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:312)
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:219)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.loadModel(Atl RegularVM.java:220)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getSourceMode ls(AtlRegularVM.java:138)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
severe: null
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getSourceMode ls(AtlRegularVM.java:140)
The input aaxl in validate successful. I don't understand why this
exception occurs.
Can someone help me?
Thanks in advance.
Yue
Re: [ATL] AADL Model Transformation [message #76310 is a reply to message #76289] Wed, 12 March 2008 08:19 Go to previous messageGo to next message
Apparently EMF cannot load your XML document.
According to the error message I would say that you have a typo in your
document: 'ystemType' instead of 'systemType', but I may be wrong.
If you cannot solve this information to solve your problem, could you
please post here a minimal example exhibiting the problematic behavior?
Frédéric Jouault
yue a écrit :
> rule RsysImpl{
> from
> s : core!SystemImpl
> to
> rule RsysType{
> from
> s : core!SystemType
> to
> valid reference
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> severe: null
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception occurs.
> Thanks in advance.
> Yue
Re: [ATL] AADL Model Transformation [message #76339 is a reply to message #76310] Wed, 12 March 2008 08:29 Go to previous messageGo to next message
Yes, it's strange, but the error message is 'ystemType', not 'systemType'.
This is a minimal input instance:
<core:AadlSpec xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:core="http:///AADL/core"
name="aadlClient">
<systemType name="a_temperature_client">
<comment> Client</comment>
<features>
<eventPort name="request" direction="out"/>
<eventDataPort name="response"/>
</features>
</systemType>
<systemImpl name="a_temperature_client.a_impl"
compType=" /aadlSpec[@name=aadlClient]/systemType[@name=a_temperature_c lient] "/>
</core:AadlSpec>
Is there anything wrong with it? The validate is successful.
Yue
Frédéric Jouault a écrit :
> Hello,
> Frédéric Jouault
> yue a écrit :
>> simple transfor rule for systemType and systemImpl.
>> rule RsysImpl{
>> from
>> s : core!SystemImpl
>> to
>> rule RsysType{
>> from
>> s : core!SystemType
>> to
>> valid reference
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> severe: null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> exception occurs.
>> Thanks in advance.
>> Yue
Re: [ATL] AADL Model Transformation [message #76372 is a reply to message #76339] Wed, 12 March 2008 08:49 Go to previous messageGo to next message
--------------080207080808000401080303
Yue,
It looks like the @ in front of system is missing in this path:
This doesn't look like an EMF fragment path either. EMF won't be able
to interpret it without someone writing some code for it...
Something like this is more likely to work correctly:
//@systemType[name='a_temperature_client']
yue wrote:
> Hello,
> 'systemType'.
> name="aadlClient">
> <features>
> </features>
> </systemType>
> </core:AadlSpec>
> Thanks
> Yue
> Fr
Re: [ATL] AADL Model Transformation [message #76391 is a reply to message #76372] Wed, 12 March 2008 09:02 Go to previous messageGo to next message
Hi, Ed Merks
Thank you so much, that's the problem, it works now.
Ed Merks a écrit :
> Yue,
> yue wrote:
>> Hello,
>> 'systemType'.
>> <?xml version="1.0" encoding="UTF-8"?>
>> name="aadlClient">
>> <features>
>> </features>
>> </systemType>
>> </core:AadlSpec>
>> Thanks
>> Yue
>>> Hello,
>>> your document: 'ystemType' instead of 'systemType', but I may be wrong.
>>> Regards,
>>> Frédéric Jouault
>>> yue a écrit :
>>>> Hi,
>>>> rule RsysImpl{
>>>> from
>>>> s : core!SystemImpl
>>>> to
>>>> rule RsysType{
>>>> from
>>>> s : core!SystemType
>>>> to
>>>> but when systemImpl instance is added, following exception occurs:
>>>> valid reference
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> severe: null
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> exception occurs.
>>>> Thanks in advance.
>>>> Yue
Re: [ATL] AADL Model Transformation [message #76407 is a reply to message #76391] Wed, 12 March 2008 10:15 Go to previous messageGo to next message
--------------050504020704050403090802
Hi Yue,
May I ask you how got got this model ?
Quentin
yue a
Re: [ATL] AADL Model Transformation [message #76426 is a reply to message #76407] Wed, 12 March 2008 10:41 Go to previous messageGo to next message
Hi Quentin,
the format used by Yue is the .aaxl files one, it is obtained
simply by creating an AADL diagram in OSATE.
If you want to have an EMF compliant model (i.e. with the references
a la EMF) you have to enable it in the OSATE preferences.
I hope I have answered to your question,
Ivano
Quentin Glineur ha scritto:
> Hi Yue,
> Quentin
> yue a écrit :
>> Hi, Ed Merks
>> Ed Merks a écrit :
>>> Yue,
>>> able to interpret it without someone writing some code for it...
>>> yue wrote:
>>>> Hello,
>>>> 'systemType'.
>>>> xmlns:core="http:///AADL/core" name="aadlClient">
>>>> <features>
>>>> </features>
>>>> </systemType>
>>>> </core:AadlSpec>
>>>> Thanks
>>>> Yue
>>>>> Hello,
>>>>> wrong.
>>>>> you please post here a minimal example exhibiting the problematic
>>>>> behavior?
>>>>> Regards,
>>>>> Frédéric Jouault
>>>>> yue a écrit :
>>>>>> Hi,
>>>>>> rule RsysImpl{
>>>>>> from
>>>>>> s : core!SystemImpl
>>>>>> to
>>>>>> rule RsysType{
>>>>>> from
>>>>>> s : core!SystemType
>>>>>> to
>>>>>> a valid reference
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> severe: null
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> exception occurs.
>>>>>> Thanks in advance.
>>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76441 is a reply to message #76426] Wed, 12 March 2008 10:49 Go to previous messageGo to next message
--------------090907040000030902020403
Thank you very much for the informations!
Quentin
Ivano a
Re: [ATL] AADL Model Transformation [message #76456 is a reply to message #76372] Wed, 12 March 2008 11:21 Go to previous messageGo to next message
Hello Ed Merks,
I still have one question.
This is the instance model following your advice:
name="aadlClient">
<features>
</features>
</systemType>
compType="//@systemType[name='a_temperature_client']"/>
</core:AadlSpec>
There is a model validation problem: "the required feature 'compType' of
'System Impl a_temperature_clienta_impl' must be set"
Am I set the right path?
Yue
Ed Merks a écrit :
> Yue,
> yue wrote:
>> Hello,
>> 'systemType'.
>> name="aadlClient">
>> <features>
>> </features>
>> </systemType>
>> </core:AadlSpec>
>> Thanks
>> Yue
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>> yue a écrit :
>>>> Hi,
>>>> rule RsysImpl{
>>>> from
>>>> s : core!SystemImpl
>>>> to
>>>> rule RsysType{
>>>> from
>>>> s : core!SystemType
>>>> to
>>>> valid reference
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> severe: null
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> exception occurs.
>>>> Thanks in advance.
>>>> Yue
Re: [ATL] AADL Model Transformation [message #76473 is a reply to message #76456] Wed, 12 March 2008 11:27 Go to previous messageGo to next message
Yue,
An IDREF should normally be resolved as the document is processed and
should produce an error if it fails. But it does sound like it's not
been set. You might set a breakpoint on ResourceImpl.getEObject to
monitor what happens when it's called for the string below and verify
that it's behaving correctly.
yue wrote:
> Hello Ed Merks,
> name="aadlClient">
> <features>
> </features>
> </systemType>
> </core:AadlSpec>
> of 'System Impl a_temperature_clienta_impl' must be set"
> Yue
> Ed Merks a écrit :
>> Yue,
>> yue wrote:
>>> Hello,
>>> 'systemType'.
>>> <features>
>>> </features>
>>> </systemType>
>>> </core:AadlSpec>
>>> Thanks
>>> Yue
>>>> Hello,
>>>> wrong.
>>>> behavior?
>>>> Regards,
>>>> Frédéric Jouault
>>>> yue a écrit :
>>>>> Hi,
>>>>> rule RsysImpl{
>>>>> from
>>>>> s : core!SystemImpl
>>>>> to
>>>>> rule RsysType{
>>>>> from
>>>>> s : core!SystemType
>>>>> to
>>>>> a valid reference
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> severe: null
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> exception occurs.
>>>>> Thanks in advance.
>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76506 is a reply to message #76473] Wed, 12 March 2008 13:08 Go to previous messageGo to next message
In which plug-in can I find the ResourceImpl.getEObject ?
Is it this class org.eclipse.emf.ecore.resource.impl.ResourceImpl ?
Because, when I load the file, the execution stops on a lot of elements
that does not appear in my aadl example file...
Yue
Ed Merks a écrit :
> Yue,
> yue wrote:
>> Hello Ed Merks,
>> name="aadlClient">
>> <features>
>> </features>
>> </systemType>
>> </core:AadlSpec>
>> Yue
>> Ed Merks a écrit :
>>> Yue,
>>> yue wrote:
>>>> Hello,
>>>> 'systemType'.
>>>> <features>
>>>> </features>
>>>> </systemType>
>>>> </core:AadlSpec>
>>>> Thanks
>>>> Yue
>>>>> Hello,
>>>>> wrong.
>>>>> behavior?
>>>>> Regards,
>>>>> Frédéric Jouault
>>>>> yue a écrit :
>>>>>> Hi,
>>>>>> rule RsysImpl{
>>>>>> from
>>>>>> s : core!SystemImpl
>>>>>> to
>>>>>> rule RsysType{
>>>>>> from
>>>>>> s : core!SystemType
>>>>>> to
>>>>>> a valid reference
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> severe: null
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> exception occurs.
>>>>>> Thanks in advance.
>>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76519 is a reply to message #76506] Wed, 12 March 2008 13:23 Go to previous messageGo to next message
Yue,
Yep. That's the one. That method will indeed be used a lot. Eclipse
has really cool support for conditional breakpoints if you right click
and edit the properties of the breakpoint. So you might set the
condition to
uri.toString().contains("<something-unique-in-your-instance's-URI >") or
perhaps uriFragment.contains("@system")...
yue wrote:
> elements that does not appear in my aadl example file...
> Regards
> Yue
> Ed Merks a écrit :
>> Yue,
>> yue wrote:
>>> Hello Ed Merks,
>>> <features>
>>> </features>
>>> </systemType>
>>> </core:AadlSpec>
>>> 'compType' of 'System Impl a_temperature_clienta_impl' must be set"
>>> Yue
>>> Ed Merks a écrit :
>>>> Yue,
>>>> yue wrote:
>>>>> Hello,
>>>>> 'systemType'.
>>>>> <features>
>>>>> </features>
>>>>> </systemType>
>>>>> </core:AadlSpec>
>>>>> Thanks
>>>>> Yue
>>>>>> Hello,
>>>>>> in your document: 'ystemType' instead of 'systemType', but I may
>>>>>> be wrong.
>>>>>> behavior?
>>>>>> Regards,
>>>>>> Frédéric Jouault
>>>>>> yue a écrit :
>>>>>>> Hi,
>>>>>>> rule RsysImpl{
>>>>>>> from
>>>>>>> s : core!SystemImpl
>>>>>>> to
>>>>>>> rule RsysType{
>>>>>>> from
>>>>>>> s : core!SystemType
>>>>>>> to
>>>>>>> works; but when systemImpl instance is added, following
>>>>>>> exception occurs:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> severe: null
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> this exception occurs.
>>>>>>> Thanks in advance.
>>>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76599 is a reply to message #76519] Thu, 13 March 2008 06:01 Go to previous messageGo to next message
Ed,
I traced the getEObject method.
the input:
uriFragment= "//@systemType[name=/a_temperature_client']"
and the output:
uriFragmentPath[0]=""
uriFragmentPath[1]="@systemType[name=/a_temperature_client'] "
uriFragmentPath[2]=null
uriFragmentPath[3]=null
Is this behaving correctly?
Yue
Ed Merks a écrit :
> Yue,
> condition to
> yue wrote:
>> Regards
>> Yue
>> Ed Merks a écrit :
>>> Yue,
>>> yue wrote:
>>>> Hello Ed Merks,
>>>> <features>
>>>> </features>
>>>> </systemType>
>>>> </core:AadlSpec>
>>>> Yue
>>>> Ed Merks a écrit :
>>>>> Yue,
>>>>> yue wrote:
>>>>>> Hello,
>>>>>> 'systemType'.
>>>>>> <features>
>>>>>> </features>
>>>>>> </systemType>
>>>>>> </core:AadlSpec>
>>>>>> Thanks
>>>>>> Yue
>>>>>>> Hello,
>>>>>>> be wrong.
>>>>>>> behavior?
>>>>>>> Regards,
>>>>>>> Frédéric Jouault
>>>>>>> yue a écrit :
>>>>>>>> Hi,
>>>>>>>> rule RsysImpl{
>>>>>>>> from
>>>>>>>> s : core!SystemImpl
>>>>>>>> to
>>>>>>>> rule RsysType{
>>>>>>>> from
>>>>>>>> s : core!SystemType
>>>>>>>> to
>>>>>>>> exception occurs:
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> Source)
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> severe: null
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> Thanks in advance.
>>>>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76615 is a reply to message #76372] Thu, 13 March 2008 06:47 Go to previous messageGo to next message
Hi Ed and Yue,
This topic was discussing on the Kermeta list some months
(kermeta-users@lists.gforge.inria.fr - 2007-04-13 and 2007-12-17) ago.
It seems there is a workaround to use the EMF way for the serialization:
Go in the Eclipse preferences, item "OSATE Preferences" and check the
box: "Use EMF reference format [...]".
Cyril.
Ed Merks a écrit :
> Yue,
> yue wrote:
>> Hello,
>> 'systemType'.
>> name="aadlClient">
>> <features>
>> </features>
>> </systemType>
>> </core:AadlSpec>
>> Thanks
>> Yue
>>> Hello,
>>> Regards,
>>> Frédéric Jouault
>>> yue a écrit :
>>>> Hi,
>>>> rule RsysImpl{
>>>> from
>>>> s : core!SystemImpl
>>>> to
>>>> rule RsysType{
>>>> from
>>>> s : core!SystemType
>>>> to
>>>> valid reference
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> severe: null
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> exception occurs.
>>>> Thanks in advance.
>>>> Yue
Cyril Faucher
IRISA-INRIA - Rennes, France
[Breathe life into your metamodels www.kermeta.org]
Re: [ATL] AADL Model Transformation [message #76632 is a reply to message #76615] Thu, 13 March 2008 07:07 Go to previous messageGo to next message
Hi Cyril,
Thank you so much
Yue
Cyril Faucher a écrit :
> Hi Ed and Yue,
> Best regards,
> Cyril.
> Ed Merks a écrit :
>> Yue,
>> yue wrote:
>>> Hello,
>>> 'systemType'.
>>> name="aadlClient">
>>> <features>
>>> </features>
>>> </systemType>
>>> </core:AadlSpec>
>>> Thanks
>>> Yue
>>>> Hello,
>>>> behavior?
>>>> Regards,
>>>> Frédéric Jouault
>>>> yue a écrit :
>>>>> Hi,
>>>>> rule RsysImpl{
>>>>> from
>>>>> s : core!SystemImpl
>>>>> to
>>>>> rule RsysType{
>>>>> from
>>>>> s : core!SystemType
>>>>> to
>>>>> a valid reference
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> severe: null
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> exception occurs.
>>>>> Thanks in advance.
>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76652 is a reply to message #76599] Thu, 13 March 2008 09:08 Go to previous messageGo to next message
--------------060900000901040703070402
Yue,
I gather the other mechanism is x-path based and is supported by
kermeta. In any case, the string you show below is not the same as what
I suggested earlier:
Note the ' instead of the / in front of a_temperature_client.
yue wrote:
> Ed,
> the input:
> and the output:
> Yue
> Ed Merks a
Re: [ATL] AADL Model Transformation [message #76669 is a reply to message #76652] Thu, 13 March 2008 10:26 Go to previous messageGo to next message
Sorry, a typo. :-)
As Cyril suggested, 'Use EMF reference format' like
compType="#//@systemType.0".
That will resolve this problem.
Yue
Ed Merks a écrit :
> Yue,
> yue wrote:
>> Ed,
>> the input:
>> and the output:
>> Yue
>> Ed Merks a écrit :
>>> Yue,
>>> Eclipse has really cool support for conditional breakpoints if you
>>> right click and edit the properties of the breakpoint. So you might
>>> set the condition to
>>> or perhaps uriFragment.contains("@system")...
>>> yue wrote:
>>>> Hi,
>>>> Regards
>>>> Yue
>>>> Ed Merks a écrit :
>>>>> Yue,
>>>>> and should produce an error if it fails. But it does sound like
>>>>> it's not been set. You might set a breakpoint on
>>>>> ResourceImpl.getEObject to monitor what happens when it's called
>>>>> for the string below and verify that it's behaving correctly.
>>>>> yue wrote:
>>>>>> Hello Ed Merks,
>>>>>> <features>
>>>>>> </features>
>>>>>> </systemType>
>>>>>> </core:AadlSpec>
>>>>>> Yue
>>>>>> Ed Merks a écrit :
>>>>>>> Yue,
>>>>>>> be able to interpret it without someone writing some code for it...
>>>>>>> yue wrote:
>>>>>>>> Hello,
>>>>>>>> 'systemType'.
>>>>>>>> <features>
>>>>>>>> </features>
>>>>>>>> </systemType>
>>>>>>>> </core:AadlSpec>
>>>>>>>> Thanks
>>>>>>>> Yue
>>>>>>>>> Hello,
>>>>>>>>> may be wrong.
>>>>>>>>> could you please post here a minimal example exhibiting the
>>>>>>>>> Regards,
>>>>>>>>> Frédéric Jouault
>>>>>>>>> yue a écrit :
>>>>>>>>>> Hi,
>>>>>>>>>> very simple transfor rule for systemType and systemImpl.
>>>>>>>>>> rule RsysImpl{
>>>>>>>>>> from
>>>>>>>>>> s : core!SystemImpl
>>>>>>>>>> to
>>>>>>>>>> rule RsysType{
>>>>>>>>>> from
>>>>>>>>>> s : core!SystemType
>>>>>>>>>> to
>>>>>>>>>> exception occurs:
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> Source)
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> severe: null
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> Thanks in advance.
>>>>>>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76686 is a reply to message #76669] Thu, 13 March 2008 10:31 Go to previous messageGo to next message
Yue,
Indeed, that would be the default notation you'd get serializing with
EMF. The [name='a_temperature_client'] notation (in place of .0)
you'd only get if you used EReference.eKeys to specify that the name
feature is a key...
yue wrote:
> Sorry, a typo. :-)
> Yue
> Ed Merks a écrit :
>> Yue,
>> what I suggested earlier:
>> yue wrote:
>>> Ed,
>>> the input:
>>> and the output:
>>> Yue
>>> Ed Merks a écrit :
>>>> Yue,
>>>> might set the condition to
>>>> yue wrote:
>>>>> Hi,
>>>>> Regards
>>>>> Yue
>>>>> Ed Merks a écrit :
>>>>>> Yue,
>>>>>> yue wrote:
>>>>>>> Hello Ed Merks,
>>>>>>> <features>
>>>>>>> </features>
>>>>>>> </systemType>
>>>>>>> </core:AadlSpec>
>>>>>>> Yue
>>>>>>> Ed Merks a écrit :
>>>>>>>> Yue,
>>>>>>>> it...
>>>>>>>> yue wrote:
>>>>>>>>> Hello,
>>>>>>>>> 'systemType'.
>>>>>>>>> <features>
>>>>>>>>> </features>
>>>>>>>>> </systemType>
>>>>>>>>> </core:AadlSpec>
>>>>>>>>> Thanks
>>>>>>>>> Yue
>>>>>>>>>> Hello,
>>>>>>>>>> typo in your document: 'ystemType' instead of 'systemType',
>>>>>>>>>> but I may be wrong.
>>>>>>>>>> Regards,
>>>>>>>>>> Frédéric Jouault
>>>>>>>>>> yue a écrit :
>>>>>>>>>>> Hi,
>>>>>>>>>>> model.
>>>>>>>>>>> rule RsysImpl{
>>>>>>>>>>> from
>>>>>>>>>>> s : core!SystemImpl
>>>>>>>>>>> to
>>>>>>>>>>> rule RsysType{
>>>>>>>>>>> from
>>>>>>>>>>> s : core!SystemType
>>>>>>>>>>> to
>>>>>>>>>>> exception occurs:
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> Source)
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> severe: null
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> why this exception occurs.
>>>>>>>>>>> Thanks in advance.
>>>>>>>>>>> Yue
Re: [ATL] AADL Model Transformation [message #76751 is a reply to message #76652] Fri, 14 March 2008 08:23 Go to previous messageGo to next message
Ed,
I believe you slightly misunderstood Cyril.
The code generated by EMF for OSATE has been manually modified (in
compliance with EMF, IIUC) in order to implement a different reference
serialization mechanism.
Cyril stated that OSATE itself provides an option to switch its
serialization to "standard" references; an information that he read on
the mailing list he mentioned.
(Cyril, please correct me if I am wrong.)
However, I believe the modified format should be directly usable with
EMF (and therefore with ATL) if the corresponding plugin (with the code
modification) is installed, and if the proper factory is used.
Also, I believe that files saved by EMF, but not in standard EMF format
(i.e., that cannot be read without additional specific Java code) should
be somehow marked as "tainted" (e.g., in the xmi:version attribute).
Otherwise, developers are tempted to "beautify" their "XMI" output
(making it one more non-"interchangeable" version of XM"I"), and users
get confused.
Frédéric Jouault
Re: [ATL] AADL Model Transformation [message #76767 is a reply to message #76751] Fri, 14 March 2008 11:08 Go to previous messageGo to next message
Frédéric,
Comments below.
Frédéric Jouault wrote:
> Ed,
> code modification) is installed, and if the proper factory is used.
The more XPath-like notation is quite nice.
> get confused.
Some of the things used by EMF, like attributes with QName URI pairs
instead of elements with xmi:type and hrefs, are not part of the current
XMI specification but are working their way into the latest
specification (or so I've heard). The XMI specification seems to
require xmi:id, and while that's a very robust serialization mechanism,
it also fills up instances with a lot of additional information. It may
well be necessary to be able to reference instances in resources that
are not an XMI serialization and do not support the notion of a unique
identifier, so having a structural way of specifying how to locate an
instance seems to be a gap. In any case, EMF generally provides many
choices, e.g., use XMLResourceImpl instead of XMIResourceImpl if you
don't want to produce an XMI serialization that doesn't have a
conforming xmi:id based referencing mechanism. XMI serializations
aren't generally all that readable, and the UUID-based referencing
mechanism is significant factor in that lack of readability...
> Best regards,
> Frédéric Jouault
Re: [ATL] AADL Model Transformation [message #76783 is a reply to message #76289] Fri, 14 March 2008 11:31 Go to previous messageGo to next message
Originally posted by: lwrage.sei.cmu.edu
Yue,
to confirm what has been written before:
You have two options to process aaxl files with ATL. The first is to
write references as standard EMF references using the OSATE preference
setting. The second id to install ATL and OSATE in the same eclipse
instance. You can then use metamodel by uri (http://AADL/core)in the ATL
launch configuration. I've used the second approach myself.
- Lutz
yue wrote, on 3/12/2008 6:32 AM:
> rule RsysImpl{
> from
> s : core!SystemImpl
> to
> rule RsysType{
> from
> s : core!SystemType
> to
> valid reference
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> severe: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception occurs.
> Thanks in advance.
> Yue
Re: [ATL] AADL Model Transformation [message #90281 is a reply to message #76783] Mon, 22 September 2008 10:08 Go to previous messageGo to next message
Hi Lutz ,
I use ATL and OSATE in the same eclipse instance as you advised.
But I have another problem.
When I add the Allowed_Processor_Binding property in the system
implementation, the model is not accpeted and there is an error:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value
'org.eclipse.emf.ecore.impl.DynamicEObjectImpl@137854f (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@470524 (name:
ProcessorSubcomponent) (instanceClassName: null) (abstract: false,
interface: false))' is not legal.
(platform:/resource/AADL2SIGNAL/model/ClientTest.aaxl, 110, 1)
When I remove the property, the model can be accepted.
The aaxl file is like this:
<systemImpl name="client.impl" compType="#//@systemType.0">
<properties>
<propertyAssociation noMode="false"
propertyDefinition=" ../../../plugin/edu.cmu.sei.osate.workspace/resources/proper ties/AADL_Properties.aaxl#//@propertySet.0/@propertyDefiniti on.22 "
constant="false" access="false" append="false"
appliesTo="#//@systemImpl.0/@subcomponents/@processSubcomponent.0 "
derived="false">
<propertyValue xsi:type="property:ReferenceValue"
referenceElement="#//@systemImpl.0/@subcomponents/@processorSubcomponent.0 "/>
</propertyAssociation>
</properties>
<connections>
<dataConnection noMode="false" srcContext="#//@systemImpl.0"
dstContext="#//@systemImpl.0/@subcomponents/@processSubcomponent.0 "
src="#//@systemType.0/@features/@dataPort.0"
dst="#//@processType.0/@features/@dataPort.0"
timing="Immediate"/>
srcContext="#//@systemImpl.0/@subcomponents/@processSubcomponent.0 "
dstContext="#//@systemImpl.0"
src="#//@processType.0/@features/@dataPort.1"
dst="#//@systemType.0/@features/@dataPort.1" timing="Immediate"/>
</connections>
<subcomponents>
<processorSubcomponent name="T1" noMode="false"
classifier="#//@processorType.0"/>
<processSubcomponent name="the_process" noMode="false"
classifier="#//@processImpl.0"/>
<deviceSubcomponent name="the_device" noMode="false"
classifier="#//@deviceType.0"/>
<busSubcomponent name="the_bus" noMode="false"
classifier="#//@busType.0"/>
</subcomponents>
</systemImpl>
Is there anything that I missed when I generated the code?
Thank you so much.
Yue
Lutz Wrage a écrit :
> Yue,
> - Lutz
>> rule RsysImpl{
>> from
>> s : core!SystemImpl
>> to
>> rule RsysType{
>> from
>> s : core!SystemType
>> to
>> valid reference
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> severe: null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> exception occurs.
>> Thanks in advance.
>> Yue
Re: [ATL] AADL Model Transformation [message #90533 is a reply to message #76783] Thu, 25 September 2008 11:31 Go to previous message
Hi ,
I use AADL model as an source model during my ATL transformation.
I have such a problem.
When I add some property in the system or process or any component
But if I remove the property, the model can be accepted.
<properties>
derived="false">
</properties>
<connections>
</connections>
<subcomponents>
</subcomponents>
</systemImpl>
Thank you so much.
Yue
> Yue,
> - Lutz
>> rule RsysImpl{
>> from
>> s : core!SystemImpl
>> to
>> rule RsysType{
>> from
>> s : core!SystemType
>> to
>> valid reference
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> severe: null
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> exception occurs.
>> Thanks in advance.
>> Yue
Previous Topic:[ATL] Saving models doesn't use the device letter with windows
Next Topic:[ATL] load AADL Model problem
Current Time: Sun Aug 31 12:05:57 EDT 2025
Powered by FUDForum. Page generated in 0.08456 seconds
