| Installing on Eclipse 3.4 [message #76245] |
Thu, 17 July 2008 14:20  |
I understand that I must use 2.0 on Ganymede, so must I use the latest
integration build? Is it fairly stable?
Glen.
| Re: Installing on Eclipse 3.4 [message #77559 is a reply to message #76245] |
Fri, 01 August 2008 08:25   |
Originally posted by: quasar.ja.rosz.org
So, i have a question about this.
If i read here:
http://wiki.eclipse.org/PDT/Installation
it claims installation is very simple - just install the package.
However, based on some other information i've seen around, and what has
been said on this thread, it sounds like you actually have to install some
of the extras (all of them?) such as those listed on the page about the
specific build (ie,
http://download.eclipse.org/tools/pdt/downloads/release.php? release=I20080722).
Things like EMF, XSD, GEF, DLTK? This seems like a lot to install, but i
can give it a shot if it's needed.
I followed the wiki instructions and it kinda works, but gives the
"Selection Job title" error whenever i open a .php file.
Thanks for any input!
Quasar
| Re: Installing on Eclipse 3.4 [message #77634 is a reply to message #77575] |
Sat, 02 August 2008 16:03  |
Originally posted by: tefl.ebcidiomas.com
Standard install Ganymede with PDT 2 gave me the section titile error.
I installed dltk-I-I200807211242-200807211242-incubation and it went away
(R1.0 Mon, 21 Jul 2008 -- 12:42 (UTC))
This version and later versions can be found at
http://download.eclipse.org/technology/dltk/downloads/ in the Integration
downloads section.
Windows install procedure: download and unzip the file then start eclipse,
then click help, software updates, add site, local then browse to the
directory where you unzipped the file. Click OK until the install starts.
If you get the message that the DLTK is already installed and that Eclipse
will update what you've got, click OK and continue until prompted to
restart. Do the restart and PDT should now work without the section titile
error.
FUDForum. Page generated in 0.06721 seconds
