Home » Eclipse Projects » Eclipse Platform » classpathVariableInitializer doesn't seem to work under Eclipse 2.01
classpathVariableInitializer doesn't seem to work under Eclipse 2.01 [message #76168] Tue, 17 June 2003 07:05
Originally posted by: frank.weber.gmx.at
I try to set a classpath variable with the extension point
org.eclipse.jdt.core.classpathVariableInitializer. The whole thing works
fine with Eclipse 2.1, but it doesn't work under 2.01 (200208291828). The
initialize method will not be called.
I am using a simple "Hello World Plugin" and add a simple
classpathVariableInitializer to the Project.
This is my plugin.xml:
<plugin
id="hallo"
name="hallo Plug-in"
version="1.0.0"
provider-name=""
class="hallo.halloPlugin">
<runtime>
<library name="hallo.jar"/>
</runtime>
<requires>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.jdt.core"/>
</requires>
<extension
point="org.eclipse.ui.actionSets">
<actionSet
label="Sample Action Set"
visible="true"
id="hallo.actionSet">
<menu
label="Sample &amp;Menu"
id="sampleMenu">
<separator
name="sampleGroup">
</separator>
</menu>
<action
label="&amp;Sample Action"
icon="icons/sample.gif"
class="hallo.actions.SampleAction"
tooltip="Hello, Eclipse world"
menubarPath="sampleMenu/sampleGroup"
toolbarPath="sampleGroup"
id="hallo.actions.SampleAction">
</action>
</actionSet>
</extension>
<extension
point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="org.eclipse.ui.resourcePerspective">
<actionSet
</actionSet>
</perspectiveExtension>
</extension>
<extension
point="org.eclipse.jdt.core.classpathVariableInitializer">
<classpathVariableInitializer
variable="HALLO"
class="hallo.Hallo"/>
</extension>
</plugin>
The class hallo.Hallo exists and looks like this:
package hallo;
import org.eclipse.core.runtime.IPath;
import org.eclipse.core.runtime.Path;
import org.eclipse.jdt.core.ClasspathVariableInitializer;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.jdt.core.JavaModelException;
public class Hallo extends ClasspathVariableInitializer {
public Hallo() {
super();
public void initialize(String var) {
IPath p = new Path("/home/frank/test.jar");
try {
JavaCore.setClasspathVariable(var, p, null);
} catch (JavaModelException e) {
e.printStackTrace();
Does anybody know what is wrong with the code?
Previous Topic:Plug-In samples not disposing objects
Next Topic:[Views] Communication between views.
Current Time: Fri Oct 24 18:03:23 EDT 2025
Powered by FUDForum. Page generated in 0.03101 seconds
