Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » New to JET can't access xsi:type value
New to JET can't access xsi:type value [message #76115] Wed, 21 March 2007 04:44 Go to next message
Originally posted by: evaandoli.dodo.com.au
I assume this will be a quick one for most of you
I have the following line in my XML file:
<rules xsi:type="com.ibridge.stepbystepmodel:DecisionNode" tag="WhichState">
and I want to access the type in my JET template.
I can access the 'tag' attribute using
<c:get select="$attrib/@tag" />
But I can't seem to get to the type, i have tried both:
<c:get select="$attrib/@type" />
and
<c:get select="$attrib/@xsi:type" />
Can anyone point me to the right syntax.
Thanks.
Re: New to JET can't access xsi:type value [message #76130 is a reply to message #76115] Wed, 21 March 2007 09:10 Go to previous messageGo to next message
Stu,
Please use the m2t newsgroup for JET2 questions. I've added it to the
"to" list, so you can continue to use this thread.
Stu wrote:
> and
> Thanks.
Re: New to JET can't access xsi:type value [message #76146 is a reply to message #76130] Wed, 21 March 2007 10:50 Go to previous messageGo to next message
Stu:
Short answer: you can't. OK, you can't easily.
Explanation: JET is loading the XML file using EMF's XML/XMI
deserialization, and evaluating XPath expressions on the actual EObjects.
The xsi:type gets transformed into the EObject's eClass - unfortunately, the
eClass of an EObject is not an EFeature, and is thus invisible to the XPath
engine.
Work arounds:
It looks like the 'rules' feature declared type is an abstract type, and you
want to process the concrete sub-types differently. Here are a couple of
ways to do this:
a) If you just want to process DecisionNode elements, do the following. I'm
assuming $rulesContainer is a variable referring to the parent of the nodes
<c:iterate select="$rulesContainer/rules[self::DecisionNode]"
var="decisionNode">
</c:iterate>
the predicate [self::DecisionNode] filters the elements in the 'rules'
reference list to those whose eClass has the name 'DecisionNode'. If 'rules'
feature is a containment feature, and its containing EClass has no other
containment features that can contain DecisionNodes, then you could use the
expression $rulesContainer/DecisionNode
b) If you want to process all the rules, but do something different for each
type. Try:
<c:iterate select="$rulesContainer/rules" var="node">
<c:choose>
<c:when test="$node/self::DecisionNode">
... $node is a DecisionNode
</c:when>
<c:when test="$node/self::AnotherNode">
... $node is an AnotherNode
</c:when
</c:choose>
</c:iterate>
c) More time consuming, you could write an XPath function the returns the
eClass. Then you could do:
<c:get select="eclass($attr)"/>
To write an custom XPath function, you need to create a plug-in with a
org.eclipse.jet dependency, and an org.eclipse.jet.xpathFunctions extension.
Each function is implemented as a Java class implementing the interface
org.eclipse.jet.xpath.XPathFunction and the method Object evaluate(List
arguments). I have an example that I will be putting into the jet examples
plug-in when I have time. Let me know if you're interested in this route.
Paul
> Stu wrote:
>> tag="WhichState">
>> and
>> Thanks.
Re: New to JET can't access xsi:type value [message #76241 is a reply to message #76146] Thu, 22 March 2007 06:35 Go to previous message
Now that is not the simple reply I expected :-)
I guess I could add a derived attribute to the ecore model which returns the
java class.
(let me know if you think that is a bad idea)
Stuart
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:etrgok$sdo$1@utils.eclipse.org...
> Stu:
> the eClass of an EObject is not an EFeature, and is thus invisible to the
> XPath engine.
> Work arounds:
> you want to process the concrete sub-types differently. Here are a couple
> of ways to do this:
> I'm assuming $rulesContainer is a variable referring to the parent of the
> nodes
> var="decisionNode">
> </c:iterate>
> 'rules' feature is a containment feature, and its containing EClass has no
> other containment features that can contain DecisionNodes, then you could
> use the expression $rulesContainer/DecisionNode
> each type. Try:
> <c:choose>
> </c:when>
> </c:when
> </c:choose>
> </c:iterate>
> extension. Each function is implemented as a Java class implementing the
> interface org.eclipse.jet.xpath.XPathFunction and the method Object
> evaluate(List arguments). I have an example that I will be putting into
> the jet examples plug-in when I have time. Let me know if you're
> Paul
>> Stu wrote:
>>> Hi,
>>> tag="WhichState">
>>> and
>>> Thanks.
Re: New to JET can't access xsi:type value [message #603759 is a reply to message #76115] Wed, 21 March 2007 09:10 Go to previous message
Stu,
Stu wrote:
> and
> Thanks.
Re: New to JET can't access xsi:type value [message #603761 is a reply to message #76130] Wed, 21 March 2007 10:50 Go to previous message
Stu:
engine.
Work arounds:
ways to do this:
var="decisionNode">
</c:iterate>
type. Try:
<c:choose>
</c:when>
</c:when
</c:choose>
</c:iterate>
Paul
> Stu wrote:
>> tag="WhichState">
>> and
>> Thanks.
Re: New to JET can't access xsi:type value [message #603793 is a reply to message #76146] Thu, 22 March 2007 06:35 Go to previous message
java class.
Stuart
> Stu:
> XPath engine.
> Work arounds:
> of ways to do this:
> nodes
> var="decisionNode">
> </c:iterate>
> each type. Try:
> <c:choose>
> </c:when>
> </c:when
> </c:choose>
> </c:iterate>
> Paul
>> Stu wrote:
>>> Hi,
>>> tag="WhichState">
>>> and
>>> Thanks.
Previous Topic:JDOUserException while initializing datastore
Next Topic:Newbie: teneo configuration question
Current Time: Sat Nov 15 08:16:10 EST 2025
Powered by FUDForum. Page generated in 0.03801 seconds
