Home » Modeling » GMF (Graphical Modeling Framework) » Copy/Paste
Copy/Paste [message #76030] Wed, 08 November 2006 17:14 Go to next message
Originally posted by: jr.joergreuter.ch
I wrote a GMF Diagram Editor with a Top Level Edit Part and an internal
label. When I use Copy/Paste a copy of the graphical node and its children
is created, but not the corresponding model elements.
Do I have to implement copy/paste using the EMF Clipboard support on my own
or ist there something provided by GMF.
J
Re: Copy/Paste [message #76622 is a reply to message #76030] Fri, 10 November 2006 09:51 Go to previous messageGo to next message
Hello Jörg,
There is copy/paste support in GMF. See
org.eclipse.gmf.runtime.emf.clipboard.core. Copy/paste works in the GMF
Logic Diagram Example. If you put breakpoints in the CopyOperation and
PasteOperation classes and try copy/paste in the Logic Diagram Example
you will see how this works with the model objects in the Logic Diagram.
Are you using a generated diagram editor? I don't think copy/paste
works by default in the generated editors and I am not sure if there are
issues with getting it working in the case of a generated diagram editor.
Cherie
Joerg Reuter wrote:
> Thanks
> Jörg
Re: Copy/Paste [message #76747 is a reply to message #76622] Fri, 10 November 2006 11:14 Go to previous messageGo to next message
Thanks Cherie,
yes, I use a generated editor and it seems that it only supports semantic
copy of Top Level Nodes on the Canvas level. I will follow your advice and
dig into to logic example.
J
Re: Copy/Paste [message #77016 is a reply to message #76622] Mon, 13 November 2006 05:27 Go to previous messageGo to next message
Hello Cherie,
it seems that clipboard support works also for the generated code, but only
when using one single file for the model and the diagram.
I wonder if a fix of this is scheduled?
best regards
J
Re: Copy/Paste [message #77196 is a reply to message #77016] Mon, 13 November 2006 11:03 Go to previous message
We have noticed the same issue. I have reported in gugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=164334
Yves YANG
eUML2 + eBPMN: Soyatec
"Joerg Reuter" <jr@joergreuter.ch> wrote in message
news:ej9hao$ssa$1@utils.eclipse.org...
> Hello Cherie,
> only when using one single file for the model and the diagram.
> best regards
> J
Previous Topic:Node Labels in GMF
Next Topic:Need programmatic access to ArrangeAction
Current Time: Wed Oct 29 06:43:08 EDT 2025
Powered by FUDForum. Page generated in 0.03435 seconds
