Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Duplicate properties appearing in subclass.
| Duplicate properties appearing in subclass. [message #76017] |
Tue, 20 March 2007 08:25  |
I am having an issue whereby a subclass in my Teneo generated hibernate mapping appears to be
duplicating the properties of a superclass. When attempting to initialise the database with the
mapping it throws an error :
Exception in thread "main" org.hibernate.MappingException: Repeated column in mapping for entity:
kf.CodedXSMeasure column: xsattachdataset (should be mapped with insert="false" update="false")
at org.hibernate.mapping.PersistentClass.checkColumnDuplication (PersistentClass.java:652)
at org.hibernate.mapping.PersistentClass.checkPropertyColumnDup lication(PersistentClass.java:674)
at org.hibernate.mapping.PersistentClass.checkColumnDuplication (PersistentClass.java:696)
The ecore generated from my model appears to be correct in that there is no duplication, it only
appears after generating the hibernate mapping. The classes are UncodedMeasure and CodedMeasure.
UncodedMeasure is generated correctly, but CodedMeasure is not.
My ecore looks like this:
<eClassifiers xsi:type="ecore:EClass" name="UncodedMeasure" eSuperTypes="#//Measure
base.ecore#//Codable"/>
<eClassifiers xsi:type="ecore:EClass" name="CodedMeasure" eSuperTypes="#//Measure
But my generated hibernate mapping comes out as:
<subclass entity-name="UncodedMeasure" abstract="false" lazy="false" extends="Measure"
discriminator-value="UncodedMeasure">
<meta attribute="eclassName">UncodedMeasure</meta>
<meta attribute="epackage">http://www.sdmx.org/resources/infomodel/1.0/keyfamily.xmi</meta>
</subclass>
<subclass entity-name="CodedMeasure" abstract="false" lazy="false" extends="Measure"
discriminator-value="CodedMeasure">
<meta attribute="eclassName">CodedMeasure</meta>
<property name="xsAttachDataset" lazy="false" insert="true" update="true" not-null="false"
unique="false" type="java.lang.Boolean">
<column not-null="false" unique="false" name="`xsattachdataset`"/>
</property>
<property name="xsAttachGroup" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`xsattachgroup`"/>
</property>
<property name="xsAttachSection" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`xsattachsection`"/>
</property>
<property name="xsAttachObservation" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`xsattachobservation`"/>
</property>
<property name="timeFormat" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`timeformat`"/>
</property>
<many-to-one name="CodeList" entity-name="ItemScheme"
cascade="merge,persist,save-update,lock,refresh" lazy="false" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`itemscheme_codelist_urn`"/>
</many-to-one>
</subclass>
The properties which are mapped under CodedMeasure should not be there as they form part of a class
further up the heirarchy and there is nothing in the ecore to indicate that the two classes should
be mapped differently. They do normally have some other differentiating features but I have stripped
them out to highlight the problem.
regards
Duncan
| Re: Duplicate properties appearing in subclass. [message #76049 is a reply to message #76017] |
Tue, 20 March 2007 08:39   |
Hi Duncan,
Can you send me the complete ecore?
gr. Martin
Duncan ALexander wrote:
> hibernate mapping appears to be duplicating the properties of a
> superclass. When attempting to initialise the database with the mapping
> column in mapping for entity: kf.CodedXSMeasure column: xsattachdataset
> at
> at
> at
> no duplication, it only appears after generating the hibernate mapping.
> The classes are UncodedMeasure and CodedMeasure. UncodedMeasure is
> eSuperTypes="#//Measure base.ecore#//Codable"/>
> extends="Measure" discriminator-value="UncodedMeasure">
> <meta
> </subclass>
> extends="Measure" discriminator-value="CodedMeasure">
> <meta
> update="true" not-null="false" unique="false" type="java.lang.Boolean">
> </property>
> </property>
> </property>
> </property>
> </property>
> insert="true" update="true" not-null="false">
> </many-to-one>
> </subclass>
> as they form part of a class further up the heirarchy and there is
> nothing in the ecore to indicate that the two classes should be mapped
> but I have stripped them out to highlight the problem.
> regards
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Duplicate properties appearing in subclass. [message #76066 is a reply to message #76049] |
Tue, 20 March 2007 10:49   |
Martin et al,
in leiu of a fix for this should I be able to add annotations to change the attributes of these fields.
Is it possible to set the insert and update attributes of a mapped property through annotations ?
Thanks again
Duncan
Martin Taal wrote:
> Hi Duncan,
> gr. Martin
>> at
>> at
>> at
>> is no duplication, it only appears after generating the hibernate
>> <meta
>> </subclass>
>> <meta
>> </property>
>> </property>
>> </property>
>> insert="true" update="true" not-null="false" unique="false"
>> </property>
>> </property>
>> </many-to-one>
>> </subclass>
>> regards
>> Duncan
| Re: Duplicate properties appearing in subclass. [message #76082 is a reply to message #76066] |
Tue, 20 March 2007 10:55  |
Hi Duncan,
It is partially a bug in the multi-inheritance handling. I solved this and will check this in later
today probably.
However on other issue remains: the uncodedmeasure and codedmeasure should have the same properties
in the hbm file. The difference happens because when I read the ecore files (to generate the hbm)
the uncodedmeasure has only one supertype (measure) while the codedmeasure has two supertypes:
measure and codable.
The strange thing is that when I open the ecores in the standard emf ecore editor that
uncodedmeasure has two supertypes (measure and codable).
When you look at your generated code and debug at runtime can you see which supertypes the
UncodedMeasure has?
Which version of emf are you using? I am using emf 2.3.
gr. Martin
> Martin et al,
> Thanks again
> Duncan
> Martin Taal wrote:
>> Hi Duncan,
>> gr. Martin
>>> Hi,
>>> at
>>> at
>>> at
>>> <meta
>>> </subclass>
>>> lazy="false" extends="Measure" discriminator-value="CodedMeasure">
>>> <meta
>>> </property>
>>> </property>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </subclass>
>>> there as they form part of a class further up the heirarchy and there
>>> is nothing in the ecore to indicate that the two classes should be
>>> features but I have stripped them out to highlight the problem.
>>> regards
>>> Duncan
The Netherlands
| Re: Duplicate properties appearing in subclass. [message #603736 is a reply to message #76017] |
Hi Duncan,
gr. Martin
> at
> at
> at
> <meta
> </subclass>
> <meta
> </property>
> </property>
> </property>
> </property>
> </property>
> </many-to-one>
> </subclass>
> regards
> Duncan
The Netherlands
| Re: Duplicate properties appearing in subclass. [message #603740 is a reply to message #76049] |
Martin et al,
Thanks again
Duncan
Martin Taal wrote:
> Hi Duncan,
> gr. Martin
>> at
>> at
>> at
>> <meta
>> </subclass>
>> <meta
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </many-to-one>
>> </subclass>
>> regards
>> Duncan
| Re: Duplicate properties appearing in subclass. [message #603744 is a reply to message #76066] |
Hi Duncan,
today probably.
UncodedMeasure has?
gr. Martin
> Martin et al,
> Thanks again
> Duncan
> Martin Taal wrote:
>> Hi Duncan,
>> gr. Martin
>>> Hi,
>>> at
>>> at
>>> at
>>> <meta
>>> </subclass>
>>> <meta
>>> </property>
>>> </property>
>>> </property>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </subclass>
>>> regards
>>> Duncan
The Netherlands
Current Time: Sun Nov 09 04:41:19 EST 2025
Powered by FUDForum. Page generated in 0.04492 seconds
