Home » Archived » XML Schema Definition (XSD) » Finding type-references of local-elements
| Finding type-references of local-elements [message #6853] |
Mon, 18 November 2002 11:34  |
Originally posted by: thomas.hoffmann.i-one.at
Hi!
I have a problem to get the complex-type-definition of a locally-defined
element, which uses a reference to a complex type.
For example:
I have a schema (listing at the end of this posting) and I want to get the
the complex-Type-Definition of the testlecturer-element (the fifth
xsd-element under the rootelement "lva").
With
schema.resolveElementDeclaration(c_schema.getTargetNamespace (), "testlecturer
") I get an XSDElementDeclaration.
Using the toString() method leads to the following output.
org.eclipse.xsd.impl.XSDElementDeclarationImpl@439a20 (element: null) (name:
testlecturer, targetNamespace: http://www.infosys.tuwien.ac.at/ns/xml)
(value: null, constraint: <unset>, form: <unset>, lexicalValue: null)
(nillable: <unset>, disallowedSubstitutions: null,
substitutionGroupExclusions: null, abstract: <unset>, lexicalFinal: null,
block: null).
So I am not able to receive a valid XSDTypeDefinition-Objekt with
elem.getTypeDefinition() because the Type-Definition is null;
The testlecturer-element is also not available in the
Element-Declarations-List which you get with
schema.getElementDeclarations(). Why?
Has anyone an idea how I can get the complex-type-definition of testlecturer
when I have only the name of the element ("testlecturer") and the namespace?
Thanks in advance,
Tom.
________________schema_____________________
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://www.infosys.tuwien.ac.at/ns/xml"
xmlns:targetNS="http://www.infosys.tuwien.ac.at/ns/xml"
<xsd:element name="lva">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref="targetNS:contents" minOccurs="1"
maxOccurs="1" />
<xsd:element ref="targetNS:lecturer" minOccurs="1" maxOccurs="1"
<xsd:element ref="targetNS:grading" minOccurs="1" maxOccurs="1"
<xsd:element ref="targetNS:students" minOccurs="1" maxOccurs="1"
<xsd:element name="testlecturer" type="targetNS:SimplePerson" />
</xsd:sequence>
<xsd:attribute name="lvatype" type="targetNS:lvatype" default="VO"
use="optional" />
<xsd:attribute name="number" type="xsd:integer" use="required" />
</xsd:complexType>
</xsd:element>
<xsd:element name="grading" type="xsd:string" fixed="very good" />
<xsd:complexType name="SimplePerson">
<xsd:sequence>
<xsd:element ref="targetNS:firstname" />
<xsd:element ref="targetNS:lastname" />
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="ComplexPerson">
<xsd:complexContent>
<xsd:extension base="targetNS:SimplePerson">
<xsd:sequence>
<xsd:element form="qualified" name="street" type="xsd:string" />
<xsd:element form="qualified" name="email" type="targetNS:MyEmail"
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="contents">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref="targetNS:overview" minOccurs="0" maxOccurs="1" />
<xsd:element ref="targetNS:item" minOccurs="1" maxOccurs="unbounded" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:simpleType name="lvatype">
<xsd:restriction base="xsd:string">
<xsd:enumeration value="VO" />
<xsd:enumeration value="VU" />
<xsd:enumeration value="LU" />
</xsd:restriction>
</xsd:simpleType>
<xsd:simpleType name="MyEmail">
<xsd:pattern value="\p{L}{2,}@\p{L}{1,}(.\p{L}{1,})*"/>
</xsd:restriction>
</xsd:simpleType>
<xsd:element name="overview" type="xsd:string" />
<xsd:element name="item" type="xsd:string" />
<xsd:element name="lecturer" type="targetNS:SimplePerson" />
<xsd:element name="students">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref="targetNS:student" minOccurs="1" maxOccurs="unbounded" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="student" type="targetNS:ComplexPerson" />
<xsd:element name="firstname" type="xsd:string" />
<xsd:element name="lastname" type="xsd:string" />
</xsd:schema>
_________________________________________________
| Re: Finding type-references of local-elements [message #6879 is a reply to message #6853] |
Mon, 18 November 2002 13:27  |
Thomas,
Only global element declarations will appear in a schema's
getElementDeclarations and only global element declarations can be resolved
given just a namespace and a local name.
Your element "testlecturer" is a local element declaration. To resolve it
correctly, a context specifying a complex type definition is needed in addition
to a namespace and a local name. I.e., you need to search the complex type
definition's particles to resolve the namespace and local name to an element
declaration. (It may occur more than once in the content, but each occurrence
is required to have the identical type.) There is no convenience method to
perform this lookup.
Thomas Hoffmann wrote:
> Hi!
> For example:
> With
> block: null).
> Thanks in advance,
> Tom.
> <xsd:complexType>
> <xsd:sequence>
> maxOccurs="1" />
> </xsd:sequence>
> use="optional" />
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
Ed Merks
| Re: Finding type-references of local-elements [message #563868 is a reply to message #6853] |
Thomas,
> Hi!
> For example:
> With
> block: null).
> Thanks in advance,
> Tom.
> <xsd:complexType>
> <xsd:sequence>
> maxOccurs="1" />
> </xsd:sequence>
> use="optional" />
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:restriction>
> </xsd:simpleType>
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
Ed Merks
Current Time: Wed Nov 05 18:03:20 EST 2025
Powered by FUDForum. Page generated in 0.03009 seconds
