Home » Language IDEs » PHP Development Tools (PDT) » syntax error, unexpected 'version'
syntax error, unexpected 'version' [message #75890] Mon, 14 July 2008 14:51 Go to next message
I've inherited some php files and among them is a PHP-generated xml file
with the following format:
<?xml version="1.0"?>
<?php
echo "
--- the xml syntax here ---
and PDT is flagging the word 'version' with the message - syntax error,
unexpected 'version' ... how can I dispose of this syntax error?
Richard
Re: syntax error, unexpected 'version' [message #75908 is a reply to message #75890] Mon, 14 July 2008 15:16 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
Delete the first line. Or, if the contents in the echo "..." are just
XML w/o any PHP variables.. then just remove the first three lines (up
to echo ") and the last two ("; ?>), since there's no reason that this
file needs to be .php if it's in fact just .xml.
Nick
Richard Geddes wrote:
> <?php
> echo "
> Thanks
> Richard
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: syntax error, unexpected 'version' [message #75922 is a reply to message #75908] Mon, 14 July 2008 16:37 Go to previous message
Thanks... a little common sense goes a long way!
> Nick
>> file with the following format:
>> <?php
>> echo "
>> error, unexpected 'version' ... how can I dispose of this syntax error?
>> Thanks
>> Richard
Previous Topic:Open Declaration - Text Completion
Next Topic:Xdebug - breakpoints don't work
Current Time: Tue Nov 18 21:15:26 EST 2025
Powered by FUDForum. Page generated in 0.24298 seconds
