| [Teneo] Mapping generation requires plugin runtime dependency [message #75879] |
Sat, 17 March 2007 20:37  |
Hi Martin,
I noticed that generating a mapping file for an ecore requires to add a
plugin runtime dependency on o.e.e.teneo.hibernate.
Maybe this should not be a requirement. In fact, the plugin where you
generate a mapping may not be the plugin which runs and configure the
datastore.
Didier.
| Re: [Teneo] Mapping generation requires plugin runtime dependency [message #75915 is a reply to message #75879] |
Sun, 18 March 2007 09:51  |
Hi Didier,
The mapping generation is not run as a standard eclipse menu option (in the classpath of the
installed eclipse plugins). Instead it is run as a java application (just as you would choose run as
> java application). See the class: org.eclipse.emf.teneo.eclipse.genxml.RunGenerateJob.
The generate-mapping program runs in the classpath of the model project (with the generated java
sources). This is done so that the generated model classes can be loaded during the generate-mapping
run. Sometimes Teneo needs to know the generated java implementation classes. These are only
available by actually instantiating an eclass.
Because the generate-mapping program uses the classpath of the model project, the model project
requires the hibernate plugin (actually the org.eclipse.emf.teneo.hibernate.mapper plugin should be
enough).
gr. Martin
Ptitjes wrote:
> Hi Martin,
> datastore.
> Didier.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Mapping generation requires plugin runtime dependency [message #603708 is a reply to message #75879] |
Hi Didier,
enough).
gr. Martin
Ptitjes wrote:
> Hi Martin,
> datastore.
> Didier.
The Netherlands
FUDForum. Page generated in 0.04280 seconds
