Home » Eclipse Projects » Equinox » Embed Jetty into Equinox
Embed Jetty into Equinox [message #75813] Mon, 30 October 2006 08:32 Go to next message
Originally posted by: janos.varadi.googlemail.com
I try to Embed Jetty as a Bundle in Equinox.
I basically got it to work but following problems occured during the "SETUP"
but
I was not able to import the CVS project org.mortbay.jetty under TOOLS
Project ORBIT fully. Somehow it only imports the .project and readme.txt
file. Does somebody know why?
I also have another question. Is session management included in Jetty?
I try to implement Session Management into OSGI. Is anybody already working
on this task?
Thanks a lot for your answer
J
Re: Embed Jetty into Equinox [message #75830 is a reply to message #75813] Mon, 30 October 2006 11:27 Go to previous messageGo to next message
Originally posted by: simon.kaegi.cognos.com
Hi Janos,
Orbit manages multiple versions of 3rd part libraries so the HEAD is really
a place holder. Specific versions of the bundle are stored on branches. The
branch you want is v5_1_11. You can use Team->Switch to another branch or
version...
With that said, It's a lot easier to just import the Jetty based Http
Service Teamset from
http://www.eclipse.org/equinox/server/http_in_equinox.php. The correct
branch selection and projects are already set up for consumption.
-Simon
"Janos Varadi" <janos.varadi@googlemail.com> wrote in message
news:ei4uu5$4rp$1@utils.eclipse.org...
> "SETUP" but
> working on this task?
> J
Re: Embed Jetty into Equinox [message #75864 is a reply to message #75830] Tue, 31 October 2006 05:30 Go to previous messageGo to next message
Hi Simon.
Thanks for the hint. I have another question regarding to Jetty in OSGI.
My task is to have a Delegate Servlet which generates for each user (per
Session) an instance of a class.
These intances should be referenced by an ID which could be transfered
through Session (URL or Cookie). Basically
the requests will be delivered to the correct instance of the class.
The generated objects will be destroyed after a session timeout.
I am a beginner with servlets so if you have a hint or advise let me know.
"Simon Kaegi" <simon.kaegi@cognos.com> schrieb im Newsbeitrag
news:ei596u$c46$1@utils.eclipse.org...
> Hi Janos,
> really a place holder. Specific versions of the bundle are stored on
> branches. The branch you want is v5_1_11. You can use Team->Switch to
> another branch or version...
> -Simon
>> "SETUP" but
>> J
Re: Embed Jetty into Equinox [message #75898 is a reply to message #75864] Tue, 31 October 2006 10:03 Go to previous message
Hi Janos,
If you need explicit lifecycle support on objects stored in the session have
them implement HttpSessionBindingListener.
HTH
-Simon
news:ei78km$r57$1@utils.eclipse.org...
> Hi Simon.
> Thanks
>> Hi Janos,
>> -Simon
>>> "SETUP" but
>>> J
Previous Topic:Start Eclipse with all installed bundles
Next Topic:Eclipse Plugin and Tomcat - access
Current Time: Sat Nov 08 20:01:42 EST 2025
Powered by FUDForum. Page generated in 0.03886 seconds
