| xsd plugin [message #75690] |
Tue, 16 September 2008 05:06  |
hello,
which version of xsd plugin(org.eclipse.xsd jar file)
is compatible with eclipse 3.3
| Re: xsd plugin [message #75771 is a reply to message #75754] |
Wed, 17 September 2008 02:03  |
Gitanjali,
XSD depends on EMF's core runtime, so you'll need org.eclipse.emf.ecore
and org.eclipse.emf.common.
Gitanjali Punj wrote:
> Hello,
> To use the XSDResourceImpl class we need to add
> org.eclipse.xsd jar file .Besides that any other jar files are needed
> to be mentioned in the classpath Because it keeps
> giving "no class definition found" whenever i try to access
> this class
| Re: xsd plugin [message #603313 is a reply to message #75690] |
Tue, 16 September 2008 06:21  |
Gitanjali,
Whatever version of Eclipse you have, subtract 1.0.0, and use that
version of XSD.
> hello,
| Re: xsd plugin [message #603317 is a reply to message #75738] |
Tue, 16 September 2008 23:43  |
are needed to be mentioned in the classpath Because it keeps
this class
| Re: xsd plugin [message #603318 is a reply to message #75754] |
Gitanjali,
> Hello,
> this class
FUDForum. Page generated in 0.04344 seconds
