Home » Archived » XML Schema Definition (XSD) » xsd plugin
xsd plugin [message #75690] Tue, 16 September 2008 05:06 Go to next message
hello,
which version of xsd plugin(org.eclipse.xsd jar file)
is compatible with eclipse 3.3
Re: xsd plugin [message #75738 is a reply to message #75690] Tue, 16 September 2008 06:21 Go to previous messageGo to next message
Gitanjali,
Whatever version of Eclipse you have, subtract 1.0.0, and use that
version of XSD.
Gitanjali Punj wrote:
> hello,
Re: xsd plugin [message #75754 is a reply to message #75738] Tue, 16 September 2008 23:43 Go to previous messageGo to next message
To use the XSDResourceImpl class we need to add
org.eclipse.xsd jar file .Besides that any other jar files
are needed to be mentioned in the classpath Because it keeps
giving "no class definition found" whenever i try to access
this class
Re: xsd plugin [message #75771 is a reply to message #75754] Wed, 17 September 2008 02:03 Go to previous message
Gitanjali,
XSD depends on EMF's core runtime, so you'll need org.eclipse.emf.ecore
and org.eclipse.emf.common.
> Hello,
> org.eclipse.xsd jar file .Besides that any other jar files are needed
> this class
Re: xsd plugin [message #603313 is a reply to message #75690] Tue, 16 September 2008 06:21 Go to previous message
Gitanjali,
version of XSD.
> hello,
Re: xsd plugin [message #603317 is a reply to message #75738] Tue, 16 September 2008 23:43 Go to previous message
this class
Re: xsd plugin [message #603318 is a reply to message #75754] Wed, 17 September 2008 02:03 Go to previous message
Gitanjali,
> Hello,
> this class
Previous Topic:xsd import
Next Topic:xsd import
Current Time: Thu Oct 30 03:29:26 EDT 2025
Powered by FUDForum. Page generated in 0.12560 seconds
