Home » Eclipse Projects » Eclipse Platform » standalone info center
standalone info center [message #75681] Mon, 16 June 2003 12:38 Go to next message
Originally posted by: vranganath.cox.net
I use the following command to start standalone info center.
java -classpath
/home/venku/projects/PEPSE/eclipse/plugins/org.eclipse.help_ 2.1.0/help.jar
org.eclipse.help.standalone.Infocenter -command start -eclipsehome
/home/venku/projects/PEPSE/eclipse -port 8081
GEF help node is not displayed when I point to this location. However,
if I access the help system via "help->help contents" from within
eclipse, I can see GEF help node. Any idea what could be going wrong?
Env: Eclipse 3.0 0611 integration build with GEF 0612 integration build
on Sun java 1.4.1 and RH 9.0.
waiting for reply,
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: standalone info center [message #77871 is a reply to message #75681] Wed, 18 June 2003 12:15 Go to previous messageGo to next message
I suspect it is related to the fact that "Pending Changes" update dialog
cannot be displayed by Infocenter, as I have got the problem if I ran
Eclipse after installing it, then installed GEF.
Try deleting a
/home/venku/projects/PEPSE/eclipse/workspace/.metadata/.conf ig directory (or
the whole /home/venku/projects/PEPSE/eclipse/workspace), and start the
Infocenter. If it cures the problem, please open a bug against Help, and we
will work with Update to fix the issue.
Konrad Kolosowski
"Venkatesh Prasad Ranganath" <vranganath@cox.net> wrote in message
news:bckrpi$fjs$1@rogue.oti.com...
> java -classpath
> waiting for reply,
Re: standalone info center [message #77999 is a reply to message #77871] Wed, 18 June 2003 14:32 Go to previous message
>Try deleting a
>Konrad Kolosowski
It does not help even on removing .config directory. However, I did not
try the latter solution as I kinda messed things up when I did so last
time. I guess I will open a bug report.
>>Hi,
>>java -classpath
>>waiting for reply,
Previous Topic:Third mouse button under X11
Next Topic:Eclipse / JCE / PBEWithMD5AndDES
Current Time: Fri Nov 07 07:32:45 EST 2025
Powered by FUDForum. Page generated in 0.03979 seconds
