Home » Newcomers » Newcomers » Trouble starting Eclipse
| Trouble starting Eclipse [message #75665] |
Wed, 08 June 2005 15:25  |
Originally posted by: thomas.cormode.teckcominco.com
I have been using Eclipse for the last few months with no problems. I
downloaded 3.1RC1 today and erased my previous Eclipse version. Then I
unzipped the new version and tried to run it. I get the follwing message
after the splash screen:
Eclipse
An error has occurred. See the log file
d:\Program
OK
I reinstalled 3.0.2 but now I am getting the same error. I search the
newsgroup archives and found that similar problems were had with java
versions < 1.4. As can be seen in the log file, I am using java 1.5.0_03.
An extract from the log file is below. Please help!
T. Cormode
!SESSION Jun 08, 2005 14:27:42.859
eclipse.buildId=M200503110845
java.version=1.5.0_03
!ENTRY org.eclipse.osgi Jun 08, 2005 14:27:42.859
!MESSAGE parse.error
!STACK 0
org.xml.sax.SAXParseException: URI was not reported to parser for entity
[document]
<snip>
!ENTRY org.eclipse.core.runtime 2 1 Jun 08, 2005 14:27:43.203
!MESSAGE Problems parsing plug-in manifest for:
"initial@reference:file:d:/Program
Files/eclipse/plugins/org.eclipse.core.runtime_3.0.2/".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 08, 2005 14:27:43.203
!MESSAGE Parsing error in "plugin.xml" [line 1, column 0]: "URI was not
reported to parser for entity [document]".
!STACK 0
[document]
<snip>
!ENTRY org.eclipse.core.runtime 2 1 Jun 08, 2005 14:27:43.234
Files/eclipse/plugins/org.eclipse.update.configurator_3.0.0/ ".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Jun 08, 2005 14:27:43.234
!STACK 0
[document]
<snip>
| Re: Trouble starting Eclipse [message #75853 is a reply to message #75665] |
Wed, 08 June 2005 22:50   |
> Eclipse
> d:\Program
> OK ---------------------------
> T. Cormode
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> [document]
> <snip>
> !STACK 0
> [document]
> <snip>
> !STACK 0
> [document]
> <snip>
I run 3.1M7.
A simple question but when you started the Eclipse IDE did you use the
-clean as a parameter.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
| Re: Trouble starting Eclipse [message #76074 is a reply to message #75853] |
Thu, 09 June 2005 10:39   |
I erased Eclipse and unzipped 3.1RC1 and ran Eclipse from DOS using the
-clean parameter (you can see it in the log file). Unfortunately, I got
the same result. I appreciate any suggestions.
T. Cormode
!SESSION 2005-06-09 10:31:11.609
eclipse.buildId=I20050527-1300
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.core.runtime 2 1 2005-06-09 10:31:13.375
"initial@reference:file:plugins/org.eclipse.core.runtime_3.1.0.jar/".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 2005-06-09 10:31:13.375
!STACK 0
IchBin wrote:
> I run 3.1M7.
>> Eclipse
>> d:Program
>> T. Cormode
>> !STACK 0
>> [document]
>> <snip>
>> !STACK 0
>> [document]
>> <snip>
>> !STACK 0
>> [document]
>> <snip>
| Re: Trouble starting Eclipse [message #76106 is a reply to message #75665] |
Thu, 09 June 2005 10:49   |
> Eclipse
> d:\Program
> T. Cormode
> !STACK 0
> [document]
> <snip>
I don't know what the cause is, but I can tell you that the error you're
getting is not the same as the one when trying to run Eclipse on a < 1.4
JDK. In that case, people get a "class not found" error because there is
no XML parser. In your case, the XML parser is there but appears to be
choking on something.
Sorry I can't help more - I just thought this info might prevent you
from going on a wild goose chase about JDK versions that isn't likely
your problem.
HTH,
Eric
| Re: Trouble starting Eclipse [message #76137 is a reply to message #76074] |
Thu, 09 June 2005 11:04   |
Originally posted by: hcs33.egon.gyaloglo.hu
Do you have any 3rd party xml parser in your classpath (especially in
jre\lib\ext)?
There is a bugzilla report for a similar error:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=69125
HTH,
Csaba
> T. Cormode
> !STACK 0
> IchBin wrote:
>> I run 3.1M7.
>>> Eclipse
>>> d:Program
>>> 1.5.0_03.
>>> T. Cormode
>>> !STACK 0
>>> [document]
>>> <snip>
>>> !STACK 0
>>> [document]
>>> <snip>
>>> !STACK 0
>>> [document]
>>> <snip>
| Re: Trouble starting Eclipse [message #76235 is a reply to message #76137] |
Thu, 09 June 2005 13:53   |
It seems Eclipse is only picky on the first run. I had 5 jar files from
jfreechart in my jre\lib\ext directory (gnujaxp.jar,
jcommon-1.0.0-pre2.jar, jfreechart-1.0.0-pre2.jar, junit.jar, and
servlet.jar). I removed them and ran Eclipse and it worked. I replaced
them after the first run and Eclipse still runs fine. I guess there is
some process that takes place only on the first run involving the XML
parser.
Thanks for the help,
T. Cormode
Horváth, Csaba wrote:
> jrelibext)?
> HTH,
> Csaba
>> T. Cormode
>> !STACK 0
>> IchBin wrote:
>>> I run 3.1M7.
>>>> Eclipse
>>>> d:Program
>>>> 1.5.0_03.
>>>> T. Cormode
>>>> !STACK 0
>>>> [document]
>>>> <snip>
>>>> !STACK 0
>>>> [document]
>>>> <snip>
>>>> !STACK 0
>>>> [document]
>>>> <snip>
| Re: Trouble starting Eclipse [message #76587 is a reply to message #76235] |
Fri, 10 June 2005 10:49  |
> parser.
Just a helpful aside: it is not recommended to put libraries like
JFreechart and servlet API in your jre ext directory. In fact, I always
avoid putting _anything_ in there. Just like it is better to avoid a
global system CLASSPATH, doing so help to avoid any problems such as
this one where one application might have a conflict with stuff that is
global like that.
It is a far better strategy to use shortcuts or batch/script files to
launch Java applications, because you always know exactly what JVM is
being used and exactly what is on the classpath. If you have a system
CLASSPATH and/or libs in the ext directory, it is not obvious.
HTH,
Eric
Current Time: Wed Nov 05 08:51:57 EST 2025
Powered by FUDForum. Page generated in 0.10576 seconds
