Home » Archived » Voicetools » problems with voicetools
problems with voicetools [message #6830] Fri, 26 August 2005 04:40 Go to next message
Originally posted by: kai.easyconnect.no
Error 2005-08-26 10:36:40.579 Problems occurred when invoking code from
plug-in: "org.eclipse.jface".
Does anybody else have this problem? I cannot seem to get the voicetools
editors to work. This is a fresh install. Anybody out there who know how
to remedy this?
- Kai
java.lang.NoSuchMethodError:
org.eclipse.vtp.editor.ccxml.contentassist.NoRegionContentAs sistProcessorForCCXML.addPartitionProcessor(Ljava/lang/Strin g;Lorg/eclipse/jface/text/contentassist/IContentAssistProces sor;)V
org.eclipse.vtp.editor.ccxml.contentassist.NoRegionContentAs sistProcessorForCCXML.initPartitionToProcessorMap(Unknown
Source)
org.eclipse.wst.xml.ui.internal.contentassist.NoRegionConten tAssistProcessor. <init>(NoRegionContentAssistProcessor.java:61)
org.eclipse.vtp.editor.ccxml.contentassist.NoRegionContentAs sistProcessorForCCXML. <init>(Unknown
Source)
org.eclipse.vtp.editor.ccxml.StructuredTextViewerConfigurati onCCXML.createNoRegionContentAssistProcessor(Unknown
Source)
org.eclipse.vtp.editor.StructuredTextViewerConfiguration.get ContentAssistant(Unknown
Source)
org.eclipse.wst.sse.ui.internal.StructuredTextViewer.configu re(StructuredTextViewer.java:265)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2502)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:303)
org.eclipse.wst.sse.ui.internal.StructuredTextEditor.createP artControl(StructuredTextEditor.java:850)
org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1237)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1648)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2238)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2165)
at org.eclipse.ui.internal.WorkbenchPage.access$7(WorkbenchPage .java:2157)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2143)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2138)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:120)
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:316)
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:648)
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:406)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:658)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:656)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:875)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:974)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: problems with voicetools [message #8594 is a reply to message #6830] Sun, 28 August 2005 12:34 Go to previous messageGo to next message
I'll check it out. Also, be sure and report bugs like this into
bugs.eclipse.org bug tracking site so the developers can get immediate
notification. Are you using the latest build on WTP 0.7?
"kait" <kai@easyconnect.no> wrote in message
news:demkil$dof$1@news.eclipse.org...
> to remedy this?
> - Kai
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: problems with voicetools [message #8607 is a reply to message #8594] Mon, 29 August 2005 02:47 Go to previous message
This is what I have installed:
R-0.7-200507290654/wtp-all-in-one-0.7-win32.zip and vtp-M20050817
- Kai
Re: problems with voicetools [message #572458 is a reply to message #6830] Sun, 28 August 2005 12:34 Go to previous message
> to remedy this?
> - Kai
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: problems with voicetools [message #572496 is a reply to message #8594] Mon, 29 August 2005 02:47 Go to previous message
- Kai
Previous Topic:Voice Tools Development Call Minutes: August 25, 2005
Next Topic:Just getting started...Silly question.
Current Time: Fri Nov 07 21:50:55 EST 2025
Powered by FUDForum. Page generated in 0.07687 seconds
