Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Mobile JUnit
Mobile JUnit [message #6829] Mon, 21 November 2005 05:54 Go to next message
Originally posted by: thomas.bailey.sonyericsson.com
A first stab at a rather high level Mobile JUnit use-case up at the Wiki -
http://eclipsewiki.editme.com/MTJ-mobile-junit
All feedback appreciated,
/Tom
Re: Mobile JUnit [message #8691 is a reply to message #6829] Wed, 23 November 2005 03:26 Go to previous messageGo to next message
Hi Thomas,
the Mobile JUnit UC looked quite good.
I would, however, like to see it in a more general level ie targeting the
whole Java ME platform testing not just MIDlet based test cases. The
description gives the idea that this UC would only enable testing of MIDlet
enabled devices but we need to take into consideration that the application
can be, in addition to a MIDlet, Applet, Xlet or the tradional static main()
application. I think that this UC is a good strting point, but could be
extended to target testing of all the Java ME platform application models.
Rgds,
Minna
Re: Mobile JUnit [message #8703 is a reply to message #8691] Wed, 23 November 2005 11:39 Go to previous messageGo to next message
Hi Minna,
You are quite right - it is MIDlet slanted. I realise it also assumes and
mandates UEI-ish (XEI wrapped as much as we like) behaviour is available..
execute test -> device downloads package -> device installs package ->
invokes package -> removes package. If you have, for example, a CDC
set-top box, this behaviour cannot be assumed. I guess some context
specific implementation is unavoidable whilst we have an "out-of-the box"
answer available for most scenarios.
I will address this in the UC.
/T
Minna Bloigu wrote:
> Hi Thomas,
> Rgds,
> Minna
Re: Mobile JUnit [message #8822 is a reply to message #8703] Wed, 30 November 2005 07:16 Go to previous message
Keep in mind that J2MEUnit is MIDP slanted ie no reflection..
Thomas Bailey wrote:
> Hi Minna,
> and mandates UEI-ish (XEI wrapped as much as we like) behaviour is
> available.. execute test -> device downloads package -> device installs
> package -> invokes package -> removes package. If you have, for example,
> a CDC set-top box, this behaviour cannot be assumed. I guess some
> context specific implementation is unavoidable whilst we have an
> "out-of-the box" answer available for most scenarios.
> /T
> Minna Bloigu wrote:
>> Hi Thomas,
>> MIDlet
>> application
>> main()
>> models.
>> Rgds,
>> Minna
Re: Mobile JUnit [message #562682 is a reply to message #6829] Wed, 23 November 2005 03:26 Go to previous message
Hi Thomas,
Rgds,
Minna
Re: Mobile JUnit [message #562704 is a reply to message #8691] Wed, 23 November 2005 11:39 Go to previous message
Hi Minna,
/T
Minna Bloigu wrote:
> Hi Thomas,
> Rgds,
> Minna
Re: Mobile JUnit [message #562965 is a reply to message #8703] Wed, 30 November 2005 07:16 Go to previous message
> Hi Minna,
> /T
> Minna Bloigu wrote:
>> Hi Thomas,
>> MIDlet
>> application
>> main()
>> models.
>> Rgds,
>> Minna
Previous Topic:Use Case documents
Next Topic:F2F meeting Dec 8th
Current Time: Fri Jul 18 01:23:43 EDT 2025
Powered by FUDForum. Page generated in 0.03434 seconds
