| java.lang.InstantiationException [message #75550] |
Tue, 21 December 2004 17:00  |
Originally posted by: freudi_t.yahoo.de
Got this exception in VE when I try to use a JTable with an class that
extends AbstractTableModel. Is there a way to show this JTables in VE,
for example using a different TableModel or defining it static or ...?
Thanks Thomas
| Re: java.lang.InstantiationException [message #76472 is a reply to message #75550] |
Mon, 10 January 2005 10:19  |
Hi Thomas,
Can you provide more detail of the exception please ? Is there a .log
file attached with the stack trace of the error ? What you want to do
should be supported but without more detail of your exception or more
specifics of your test case it's hard to diagnose the problem. The more
detail you can give the better.
Joe Winchester
| Re: java.lang.InstantiationException [message #604336 is a reply to message #75550] |
Hi Thomas,
Joe Winchester
FUDForum. Page generated in 0.20181 seconds
